04-17-2008, 12:05
#1 (permalink)
Member: 245748
Thanks Meter: 91 | 2 pcs Vodafone 125 successfully unlock here is the logs, Quote:
COM27 [VCP0] selected
Device: ZTE-125
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
flash chip supported
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080417-191510.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg
error: can't load database v.11
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080417-191539.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080417-191613.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 121 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
2nd, Quote:
Device: ZTE-125
Action: unlock
unlock method-1
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
file saved: C:\Program Files\InfinityBox\Pana01\125\backup_eeprom-sta_20080417-190618.B1E.bin
loading data...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080417-190637.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080417-190645.B1E.bin
done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Time used: 67 sec
Unlock instruction:
1. Power-On phone
| regards, |
