09-15-2008, 10:22 | #1 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | myphonE T11 FORMAT ERROR Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:A8C4:6733 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 97 sec Remove/Install battery now ! please check already flash error |
09-15-2008, 10:24 | #2 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | READING PLEASE ADD FILE: COM10 [VSerial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:A8C4:6733 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.61AF53B1.[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN_083D3FE8].rpl identification#1 detection finished device-id: 61AF53B1 identification#1 protocol ver: 04 ver. sw1: YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN ver. sw2: YZ06_C003.6226.L10.F03.D40.C1.U1.V1.50, 17C0C2F7 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN]... |
09-16-2008, 21:19 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Try to make "complete" format instead of "safe". Do not forget to make full flash backup before format ! |
09-17-2008, 05:09 | #4 (permalink) | |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | same sir........... Quote:
Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:A8C4:6733 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.61AF53B1.[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN_083D3FE8].rpl identification#1 detection finished device-id: 61AF53B1 identification#1 protocol ver: 04 ver. sw1: YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN ver. sw2: YZ06_C003.6226.L10.F03.D40.C1.U1.V1.50, 17C0C2F7 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN]... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... warning: wrong data size at 0x00E20400, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Finalization Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_61AF53B1_YZ06_FLB_PCB01_GPRS_MT6227_S01. BIN_083D3FE8_20080917-120749.B0X.bin Finished, time used: 237 sec Remove/Install battery now ! | |
09-17-2008, 13:20 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, You must use high-quality FTDI-based box/cable (f.e. Infinity-Box Unibox) instead of cheap and buggy chinese cables. Why you have used low quality cables in your work ? |
09-18-2008, 06:11 | #7 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | COM13 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:A8C4:6733 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.61AF53B1.[YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN_083D3FE8].rpl identification#1 detection finished device-id: 61AF53B1 identification#1 protocol ver: 04 ver. sw1: YZ06_FLB_PCB01_GPRS_MT6227_S01.BIN ver. sw2: YZ06_C003.6226.L10.F03.D40.C1.U1.V1.50, 17C0C2F7 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_61AF53B1_YZ06_FLB_PCB01_GPRS_MT6227_S01. BIN_083D3FE8_20080918-131013.B0X.bin Finished, time used: 146 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-18-2008, 07:58 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @FullFLASHgSMPH As I can see after replacing the cable process was ok @T0T0 It will be better to send flash backup to [email protected] so we will be able to upload more files in support area. |
09-18-2008, 21:54 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, One more advice how to fix problems with bad Prolific cables: install good working drivers. Here is link (see bottom of page): http://www.atm-box.com/index.php?id=utilities |
myphone s21 format error | ACID_ICED | SpiderMan | 7 | 05-23-2009 06:37 |
myPhone t11 shut off!DONE" with PADFINDER & MULTIBOX LITE" | liferocks_85 | Multi-box LITE | 1 | 10-24-2008 07:51 |
MyPhone T11 format ok and pinout here | keaelite | Infinity-Box | 1 | 09-27-2008 07:23 |
Myphone T11 backup fullflash needed | T0T0 | Infinity-Box | 3 | 09-12-2008 16:42 |
MyPhone T11??? | jhay_12 | Infinity-Box | 7 | 07-01-2008 10:50 |
