Old 11-30-2007, 05:10   #1 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
Need pin outs for this Nokia N73 model
bottom pic:
It has 18 pin connectors. have tried diffrent pin outs in pin outs folder of infinty. Does'nt work. Cannot detect unit with infinity box. Problem of unit when put with sim card display shows "ILLEGAL USE ! POWER OFF UNIT" then unit automatically shuts down. Need help ith this one. thanks in advance.
B.r.
Old 11-30-2007, 10:19   #2 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
here it is:
http://forum.gsmhosting.com/vbb/show...&postcount=545
br
Old 12-03-2007, 00:51   #3 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
THANKS BRO. THIS IS BIG HELP. DO I STILL NEED TO MAKE +,AND CHARGING CONNECTION. OR IS IT OK IF I ONLY CONNECT GROUND,RX,TX ?
b.R.
Old 12-03-2007, 01:08   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
battery pin is given only for checking if your pinout is same or not.
no need to connect it anywhere.
use just tx, rx, gnd
Old 12-03-2007, 10:04   #5 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
hello!
thanks bro for the info.
Have tried the pin out. still cannot detect unit by infinty.
need other pin outs
B.r.
The Following User Says Thank You to kungpaoski For This Useful Post:
Old 12-03-2007, 10:18   #6 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
try this connect socket press connect take out batary than put again press on ,
br
Old 12-03-2007, 12:25   #7 (permalink)
Member: 148515
hello kungpaoski!
please try one more time and change tx and rx with places with old pinout give here:
Old 12-05-2007, 06:31   #8 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
hELLO....
still cannot detect unit with infinity box.have tried interchanging rx/tx pin outs still cannot detect.................:confus ed:
B.r.
Old 12-05-2007, 08:02   #9 (permalink)
tarunvishal's Avatar
Member: 308296
Thanks Meter: 152
i have also same set we are cant find pinout beacuse the set is not MT base ic in the set use speadrem ic sory not find any solution
i need pin out for nokia 6300 dindou78 Chinese Cocktail 9 04-22-2008 07:15
i need pin out for n73 laythjg09 Infinity-Box 6 02-06-2008 18:16
need pin out for nokia n 999 chinese kasm Chinese Models & Cloned Phones 0 09-16-2007 13:33
I need pin out for Nokia 6700i ssseeerrrggg Infinity-Box 4 02-28-2007 14:35
I need pin out for Nokia 6700i ssseeerrrggg Multi-Box 2 02-28-2007 13:02
Page generated in 0.19107 seconds with 10 queries
