07-24-2017, 09:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Coolpad dazen 8297l-100 encryption unsuccessful connect ok with cm2:- I AS ABLE TO CONNECT IT TO CM2QLM IDENTIFY LOGS Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D076511 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 579C4EE04A77D6343B73A163AED1E103 ID_BLOCK_L : 60A7003221BB566230A6F3946F4D1208 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Coolpad ProdName : Coolpad8297L-I00 ProdModel : Coolpad 8297L-I00 Device : Coolpad8297L-I00 AndroidVer: 4.4.4 Manufact. : YuLong QLMxCPU : MSM8916 Done! Elapsed: 00:00:39 Code: Operation : Reset Settings 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D076511 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 579C4EE04A77D6343B73A163AED1E103 ID_BLOCK_L : 60A7003221BB566230A6F3946F4D1208 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format failed! Done! Elapsed: 00:01:16 Reconnect Power/Cable! Code: Operation : Read Flash 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D076511 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 579C4EE04A77D6343B73A163AED1E103 ID_BLOCK_L : 60A7003221BB566230A6F3946F4D1208 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Coolpad ProdName : Coolpad8297L-I00 ProdModel : Coolpad 8297L-I00 Device : Coolpad8297L-I00 AndroidVer: 4.4.4 Manufact. : YuLong QLMxCPU : MSM8916 DevInfo : MSM8916__YuLong__Coolpad__ANDR_v4.4.4__Coolpad_8297L-I00__Coolpad8297L-I00__Coolpad8297L-I00 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : param.cfg [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 1726 MiB Done! Elapsed: 00:05:00 Reconnect Power/Cable! I AM USING OLD CM2QLM VERSION 1.09 ALSO I TRIED TO FLASH IT WITH YGDP 4.4.120.00.T1.150511.8297L_I00 4.4.150.00.T1.150528.8297L_I00 BUT FLASHING FAILED ON 11% ANY HELP WBR sahil2000ind |
07-24-2017, 09:52 | #3 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: Operation : Memory Tool Init [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D076511 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 579C4EE04A77D6343B73A163AED1E103 ID_BLOCK_L : 60A7003221BB566230A6F3946F4D1208 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Set default path : E:\ABHAY IMPORTANT\INFINITY-BOX MAIN MODULE\CM2QLM\phdata\ Ready! Close MemoryTool session Done! Elapsed: 00:01:59 WBR sahil2000ind |
01-08-2018, 16:30 | #7 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Quote:
