02-09-2017, 05:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Lenovo vibe k5 {a6020a40} some issue inside there I got the above said set and got the following issue after flashing. so please check.. Operation : Identify [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Lenovo ProdName : A6020a40 ProdModel : Lenovo A6020a40 Device : A6020a40 AndroidVer: 5.1.1 Manufact. : LENOVO QLMxCPU : MSM8916 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Read Flash [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Lenovo ProdName : A6020a40 ProdModel : Lenovo A6020a40 Device : A6020a40 AndroidVer: 5.1.1 Manufact. : LENOVO QLMxCPU : MSM8916 DevInfo : MSM8916__LENOVO__Lenovo__ANDR_v5.1.1__Lenovo_A6020a40__A6020a40__A6020a40 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8929 / eMMC Firmware Size : 2135 MiB Done! Elapsed: 00:04:30 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 14789 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Recovery UserData [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Direct access : Ok! Recovery PhoneBook ... Read Ok, extract ... Load Ok! Verify Ok! Details : 0x005A,0x014E,00F8 Export HTML Ok Export VCF Ok Contacts count : 38 Data saved to : C:\InfinityBox\CM2QLM\phdata\Data_export\07093728___MSM8916__Lenovo__Lenovo_A6020a40\ Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Memory Tool Init [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Set default path : C:\InfinityBox\CM2QLM\phdata\ Ready! Operation : Test Memory [ v1.10 ] Code: Preparing memory test ... Step #1 passed Step #2 passed Memory is Ok! Clean Ok! Operation finished! Operation : Read Memory [ v1.10 ] Code: Reading selected partitions [4] [0] Read partition : MODEM Saved to : C:\InfinityBox\CM2QLM\phdata\MODEM.bin [1] Read partition : MODEMST1 Saved to : C:\InfinityBox\CM2QLM\phdata\MODEMST1.bin [2] Read partition : MODEMST2 Saved to : C:\InfinityBox\CM2QLM\phdata\MODEMST2.bin [3] Read partition : FSG Saved to : C:\InfinityBox\CM2QLM\phdata\FSG.bin [4]Read partition : USERDATA Saved to : C:\InfinityBox\CM2QLM\phdata\USERDATA.bin Operation finished! Close MemoryTool session Done! Elapsed: 00:14:52 Code: ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 26 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : misc.img Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:07:14 Reconnect Power/Cable! Operation : Reset Settings [ v1.10 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! MSC format Ok! USERDATA format Ok! CACHE format Ok! Done! Elapsed: 00:01:04 Reconnect Power/Cable! but still hang on logo.. So i flash with factory ROM. Operation : Flash [ v1.10 ] Code: ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 07093728 ID_BLOCK_I : 0091B0E1 ID_BLOCK_E : 07093728 ID_BLOCK_L : 7EA014A16D5FA326CF0D973B8A105514 ID_BLOCK_L : 69688D15ED6300F5B3E379679DA32345 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 174 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : system_26.img Flashing : system_27.img Flashing : system_28.img Flashing : system_29.img Flashing : system_30.img Flashing : system_31.img Flashing : system_32.img Flashing : system_33.img Flashing : system_34.img Flashing : system_35.img Flashing : system_36.img Flashing : system_37.img Flashing : system_38.img Flashing : system_39.img Flashing : persist_1.img Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : cache_4.img Flashing : cache_5.img Flashing : recovery.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : userdata_36.img Flashing : userdata_37.img Flashing : userdata_38.img Flashing : userdata_39.img Flashing : userdata_40.img Flashing : userdata_41.img Flashing : userdata_42.img Flashing : userdata_43.img Flashing : userdata_44.img Flashing : userdata_45.img Flashing : userdata_46.img Flashing : userdata_47.img Flashing : userdata_48.img Flashing : userdata_49.img Flashing : userdata_50.img Flashing : userdata_51.img Flashing : userdata_52.img Flashing : userdata_53.img Flashing : userdata_54.img Flashing : userdata_55.img Flashing : userdata_56.img Flashing : userdata_57.img Flashing : userdata_58.img Flashing : userdata_59.img Flashing : userdata_60.img Flashing : userdata_61.img Flashing : userdata_62.img Flashing : userdata_63.img Flashing : userdata_64.img Flashing : userdata_65.img Flashing : userdata_66.img Flashing : userdata_67.img Flashing : userdata_68.img Flashing : userdata_69.img Flashing : userdata_70.img Flashing : userdata_71.img Flashing : userdata_72.img Flashing : userdata_73.img Flashing : userdata_74.img Flashing : userdata_75.img Flashing : userdata_76.img Flashing : userdata_77.img Flashing : userdata_78.img Flashing : userdata_79.img Flashing : userdata_80.img Flashing : userdata_81.img Flashing : userdata_82.img Flashing : userdata_83.img Flashing : userdata_84.img Flashing : userdata_85.img Flashing : userdata_86.img Flashing : userdata_87.img Flashing : userdata_88.img Flashing : userdata_89.img Flashing : userdata_90.img Flashing : userdata_91.img Flashing : userdata_92.img Flashing : userdata_93.img Flashing : userdata_94.img Flashing : userdata_95.img Flashing : userdata_96.img Flashing : userdata_97.img Flashing : userdata_98.img Flashing : userdata_99.img Flashing : userdata_100.img Flashing : userdata_101.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Records in Chain : 26 Processing records now Records sequence completed! Boot settings configured! Flashing done! Done! Elapsed: 00:05:59 Reconnect Power/Cable! Now set is ok and running fine. So bro JayDi would you please check this issue?? |
02-09-2017, 13:28 | #2 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Tomorrow i have face same issue lyf 4505 working fine just update to 6.0.1v so i just bacup first phone firmware with CM2 then update with 6.0.1v after flash phone hang on logo try to format / forced fix but not success now i have no choice flash with backup firmware flash done but phone dead last firmware download extranal link and flash with cm2 now phone working. Code: Read flash Backup Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 074469A3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 20C0BA44F37F64674035DFC00F5ADAF2 ID_BLOCK_L : 1F76D87364EF5FD4E9C489464CA3BD9E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : LYF ProdName : LS-4505 ProdModel : LS-4505 Device : LS-4505 AndroidVer: 5.1.1 Manufact. : LYF QLMxCPU : MSM8909 QLMxPRJ : LYF_LS-4505_00_208_160930 DevInfo : MSM8909__LYF__LYF__ANDR_v5.1.1__LS-4505__LS-4505__LS-4505__LYF_LS-4505_00_208_160930 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 2199 MiB Done! Elapsed: 00:03:45 Code: Flash with Firmware 6.0.1 Hang On Logo Code: Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : LYF Device Manufact.: LYF Device Model : LS-4505 Device CPU : MSM8909 Device IntName : LS-4505 Device Version : 6.0.1 CU_SWVer : LYF Device Compile : 10/25/2016 11:12:56 AM Device Project : LYF_LS-4505_313_01_203_161025 Device ExtInfo : LS-4505 Load Ok! Operation : Flash [ v1.10 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 074469A3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 20C0BA44F37F64674035DFC00F5ADAF2 ID_BLOCK_L : 1F76D87364EF5FD4E9C489464CA3BD9E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Files in Chain : 25 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : misc.img Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:06:41 Reconnect Power/Cable! Code: Format / Reset Settings but same hang on logo Code: Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 074469A3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 20C0BA44F37F64674035DFC00F5ADAF2 ID_BLOCK_L : 1F76D87364EF5FD4E9C489464CA3BD9E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Repair block Ok! Repair block Ok! Repair block Ok! Forced Fix Ok! Done! Elapsed: 00:00:10 Code: Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 074469A3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 20C0BA44F37F64674035DFC00F5ADAF2 ID_BLOCK_L : 1F76D87364EF5FD4E9C489464CA3BD9E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:14 Code: Flash Own backup Firmware 5.1.1 but Dead Code: Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : LYF Device Manufact.: LYF Device Model : LS-4505 Device CPU : MSM8909 Device IntName : LS-4505 Device Version : 5.1.1 CU_SWVer : LYF Device Compile : 9/30/2016 10:49:19 AM Device Project : LYF_LS-4505_00_208_160930 Device ExtInfo : LS-4505 Load Ok! Operation : Flash [ v1.10 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 074469A3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 20C0BA44F37F64674035DFC00F5ADAF2 ID_BLOCK_L : 1F76D87364EF5FD4E9C489464CA3BD9E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Files in Chain : 25 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : misc.img Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:05:55 Code: Last Flash Extrnal link Firmware now working Fine Code: Loading firmware ... Load Ok! Operation : Flash [ v1.10 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 074469A3 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 20C0BA44F37F64674035DFC00F5ADAF2 ID_BLOCK_L : 1F76D87364EF5FD4E9C489464CA3BD9E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Files in Chain : 112 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : system_26.img Flashing : system_27.img Flashing : system_28.img Flashing : system_29.img Flashing : system_30.img Flashing : system_31.img Flashing : system_32.img Flashing : system_33.img Flashing : system_34.img Flashing : system_35.img Flashing : system_36.img Flashing : system_37.img Flashing : system_38.img Flashing : system_39.img Flashing : system_40.img Flashing : persist_1.img Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : recovery.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : userdata_36.img Flashing : userdata_37.img Flashing : userdata_38.img Flashing : userdata_39.img Flashing : userdata_40.img Flashing : userdata_41.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Records in Chain : 26 Processing records now Records sequence completed! Boot settings configured! Flashing done! Done! Elapsed: 00:06:16 Reconnect Power/Cable! So boss just check it Thanks Br ishant |
02-09-2017, 16:03 | #3 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, For both of u,, Mobiles take 20 to 30mints for first boot after format,, iam test in both of mobiles Lenovo and LYF wait for 20 to 30mints then mobiles work like charm |
The Following 2 Users Say Thank You to princesaddam For This Useful Post: |
02-09-2017, 17:05 | #4 (permalink) | |
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
thanks for suggestion. but i waited more than half an hour after flashing and format.. but other lyf phones power on after format in 5-10 mins. but in this case, it hangs on logo. so waiting for JayDi bro reply.. | |
07-28-2017, 14:18 | #6 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | Quote:
08-01-2017, 00:17 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | A6020a40_S007_161128_ROW_QPST_HW39 - Device with HW Code 39 A6020a40_S036_161205_ROW A6020a40_S027_160519_16G_ROW Model with 16Gb storage archive pass: lenovo-forums.ru p.s. Unpack and flash with CM2QLM module. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 8 Users Say Thank You to Brka For This Useful Post: |
