Old 03-11-2016, 09:17   #1 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 262
plz help i just activate cm2 But new madules not opening
i have just activate my infinty box for cm2 2 years support.. my all old module are opening but new cm2 mtk spd and rda not opening.. it says dongle not found or activate ur module ...in support area my date of validation updated.......plz help me to solve,,,,,,i also update my dongle with dongle manger...
Old 03-11-2016, 10:16   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Hello,
Download latest modules from support and try to run- Index of pub/software/updates/ (Ignore warning).
If still you have problem post your dongle serial number with problem details, if possible with screenshot.
Br.
Infinity Box Support Team.
Old 03-11-2016, 11:28   #3 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 262
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
i tried all things new module not opening when try to open says dongle not found,connect dongle and restart software but all old module in main setup 2.20a are working without problem..
Box/Dongle Serial No (S/N): 381727A3
Old 03-11-2016, 12:35   #4 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Plug only Infinity Box to your pc and disconnect all other box/dongles.
Also if you have Infinity BEST dongle running close it first and then try to open CM2 latest version module.
Br.
Old 03-11-2016, 12:39   #5 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 262
Br.
i did all things....working fine in window 7 32 bit but in xp3 not opening cm2 any module...dongle not found ...
Old 03-11-2016, 12:47   #6 (permalink)
vishnudatt's Avatar
Member: 1306196
Sonork: 100.1654602 (08104048625)
Thanks Meter: 585
Arrow
remove other dongle, and check driver
Old 03-11-2016, 12:54   #7 (permalink)
Member: 1377174
Thanks Meter: 215
problam your antivirous
first unstall setup then reboot pc and delet folder in c partion
and install agine and push your anti virous and open cm2
hope your problam will be solve
Old 03-11-2016, 13:49   #8 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 262
i did all things infinty best or cm2 not opening ...always dongle not found
Old 03-12-2016, 07:56   #9 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 262
plz help me where is the problem i am not able to use cm2 or infinty best........plz infinty support help me
Old 03-12-2016, 08:06   #10 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Do you have BEST activated on main Infinity Box or you have separate Infinity BEST dongle?
Br.
Old 03-12-2016, 08:08   #11 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 262
Br.
Infinty Best have separate dongle
Old 03-12-2016, 08:18   #12 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Close Infinity BEST software and remove Infinity BEST dongle from PC, only need to connect Infinity main Box to pc and then run CM2 latest version.
If you still have problem after this make sure correct drivers are installed and post read dongle manager log (without password).
Br.
Old 03-12-2016, 08:46   #13 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 262
Br.
DongleManager [Infinity-Box] v1.61 [3/12/2016 1:16:10 PM]
PC HWID: 9B83D6F4FDD8612B3C313B31449922EC
Box/Dongle searching...
Box/Dongle found: inf
Card-Reader: Axalto e-gate 0
HWID: 000327A3FF021982
Firmware version: 0130.02
"UK edition" status: Off
Last launched Application: 001A v.0448
Active modules:
- 00: inf v.0130
Online Service Account: Infinity-Box - Online Service
- Username: 00381727A3
Old 03-12-2016, 13:10   #14 (permalink)
Member: 148515
Thanks Meter: 13,684
Active modules:
- 00: inf v.0130
Download from support area and install LATEST Infinity CM2 software.
Run CM2 software version 1.xx
Result ?
Page generated in 0.33901 seconds with 7 queries
