03-29-2008, 12:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 39
Member: 167622 Status: Offline Sonork: 100.1608761 Thanks Meter: 40 | C707 can't access to network after flash i flash it with all suggestions in the document in the support area, so now what should i do? |
03-29-2008, 17:33 | #5 (permalink) |
Member: 167622 Status: Offline Sonork: 100.1608761 Thanks Meter: 40 | yes, but doesnt help. btw, i flashed today two c701x succesfully, both hang on startup like c707x which we have probleme with it. i think i need full flash for my phone |
03-30-2008, 00:16 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You can flash C707 with the same C701 firmware that you have used before and that was good. Are you sure that it's problem with phone but not problem with sim card that you have used for test ? Is it possible to make 112 (emergency) calls from your C707 ? Are you sure that phone is not blacklisted ? |
03-30-2008, 13:59 | #9 (permalink) | |
Member: 167622 Status: Offline Sonork: 100.1608761 Thanks Meter: 40 | Quote:
p.s: how to know if my phone is blacklisted? | |
03-30-2008, 14:26 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | how to know if my phone is blacklisted: 1. insert your own sim-card in phone and try to make some calls. If during nearest days police not come to you this means that phone is not blacklisted. 2. ask customer who bring you phone where he have got it. what to do: if you are sure that phone hardware is Ok you can try to flash phone with different flash files and see results (don't forget to make "ffs format"). Did you tried to make any calls from this phone before flashing ? What was original firmware version ? |
03-30-2008, 22:36 | #11 (permalink) | ||
so now if i flashed the phone with an-other flash from another version will it work? second question : can i try to flash c701 files to it? | ||
11-01-2008, 23:15 | #14 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | About network issue in alcatel U7 models,there's a solution: If you flashed your phone with C707X...and you get no network,then flash it with C707A and you will get network. Also if there's no network with CxxxA (for ex C707A) just flash it with CxxxX And If you think I helped you,hit THANKS button ULTIMATE GSM UNLOCK |
The Following User Says Thank You to jawad8305 For This Useful Post: |
i8510 no access to network after reset user code | M_ABRISHAMI | NSPRO | 0 | 08-27-2009 10:31 |
Help cruiser team W220i After flashing no access to network | gunjan1 | Cruiser Suite | 3 | 06-18-2008 12:01 |
after unlock 802se, can't access to memory stick? | sanitizer | Sony Ericsson | 0 | 02-17-2006 16:20 |
7600 can't select non3 networks after flash | alexh | UFS2 + UFS3-Tornadoflasher | 4 | 05-10-2005 12:23 |
