Plz Help Infinty Team Urgently I Have China Sigmatel FXD 6100 Is Kill IN Softwear What I do i dont Know Look Down fles Eprrom Prosses COM4 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1903:000E boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.72D1F8AD.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN_DCC1BFC1].rpl New firmware detected (2.73) : GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 72D1F8AD identification#1 protocol ver: 05 ver. sw 1: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN ver. sw 2: FXD-6100_01_V1.0.018_090421, 3E403E23 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E20000 Detected eeprom/ffs address is non-standard: 00E20000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00E20000 detecting eeprom/ffs size... eeprom/ffs size: 001E0000 ffs chip: 00 eeprom/ffs area: 00000000:00E20000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN]_20091202-003714.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_72D1F8AD_GINWAVE25_08A_GEMINI_PCB01_GPRS _MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN_DCC1BFC1_20091202-003717.B0X.bin Area: Eeprom/ffs flash: 98000300000001:18E59F00000000 Write: Eeprom/ffs error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: wrong answer: 3C error: flash write error: 00E00000:00002000 error: wrong answer: DB error: flash write error: 00E00000:00002000 error: wrong answer: 3B error: flash write error: 00E00000:00002000 error: wrong answer: 3B error: flash write error: 00E00000:00002000 error: wrong answer: DB error: flash write error: 00E00000:00002000 error: wrong answer: 3B error: flash write error: 00E00000:00002000 error: wrong answer: 3B error: flash write error: 00E00000:00002000 error: wrong answer: 3B error: flash write error: 00E00000:00002000 E0E00000000000E000E0E000E0E000E0E000E0E000E0E000E0 E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E0 00E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000 E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0 E000E0E0E0000000000000E0E0E0E00000E0000000E000E000 00E000E00000E000E000E000E0000000E000E0000000E000E0 0000000000E00000E000E000000000E000000000000000E0E0 00E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000 E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0 E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E0 00E0E000E0 detect device identification#2... detection phase #1... PLssssssssssssssssssssssssssssssss Give Me Solutiooooooooooooooooooon |
You must use latest software instead of use half year old software. So you must go to support area and download and install latest updates. |
