Old 12-01-2009, 14:44   #1 (permalink)
Crazy Poster
Member: 634258
Thanks Meter: 13
Plz Help Infinty Team Urgently
I Have China Sigmatel FXD 6100 Is Kill IN Softwear
What I do i dont Know
Look Down fles Eprrom Prosses
COM4 [VCP0] selected
module v2.73
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1903:000E
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:18E59F00000000
flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.72D1F8AD.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN_DCC1BFC1].rpl
New firmware detected (2.73) :
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 72D1F8AD
identification#1 protocol ver: 05
ver. sw 1: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN
ver. sw 2: FXD-6100_01_V1.0.018_090421, 3E403E23
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E20000
Detected eeprom/ffs address is non-standard: 00E20000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address confirmed by user: 00E20000
detecting eeprom/ffs size...
eeprom/ffs size: 001E0000
ffs chip: 00
eeprom/ffs area: 00000000:00E20000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN]_20091202-003714.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_72D1F8AD_GINWAVE25_08A_GEMINI_PCB01_GPRS _MT6225_S00.FXD-6100_01_V1_0_018_090421.BIN_DCC1BFC1_20091202-003717.B0X.bin
Area: Eeprom/ffs
Write: Eeprom/ffs
error: error# 0000FFFF
error: flash write error: 00E00000:00002000
error: wrong answer: 3C
error: wrong answer: DB
error: wrong answer: 3B
E0E00000000000E000E0E000E0E000E0E000E0E000E0E000E0 E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E0 00E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000 E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0 E000E0E0E0000000000000E0E0E0E00000E0000000E000E000 00E000E00000E000E000E000E0000000E000E0000000E000E0 0000000000E00000E000E000000000E000000000000000E0E0 00E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000 E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0 E000E0E000E0E000E0E000E0E000E0E000E0E000E0E000E0E0 00E0E000E0
PLssssssssssssssssssssssssssssssss Give Me Solutiooooooooooooooooooon
Old 12-01-2009, 16:16   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,204
You must use latest software instead of use half year old software.
So you must go to support area and download and install latest updates.
i need ur help infinty team urgent neeraj1st Infinity-Box 1 03-21-2009 18:22
i am not able to enter to support area plz help infinty team its urgent neeraj1st Infinity-Box 4 01-25-2009 13:43
plz help infinty team sonuveene Infinity-Box 1 09-18-2008 03:29
plz help infinty team sushilkumar Infinity-Box 1 06-13-2008 19:27
plz help infinty team sonuveene Infinity-Box 2 05-07-2008 10:36
Page generated in 0.23873 seconds with 8 queries
