plz help me i need cect q610 12pin pinout i try 2and 3 points but not sucssesant open pcb rx and tx but no workingplz help me |
hello! pin 2,3 is data pins for 8 pin connector. you have 12 pin connecotr. please add information regarding GND pin location |
Hello I tried all connections on pcb but no resultes Mine is CECT Q610 N72 SMALL WITH 1*12 CONNECTOR AND 5TH PIN IS GROUND FROM KEYBORD TOP POSITION PLEASE HELP INFINITY TEAM |
Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
