Plz Help Me infinity team Start at : [4/4/2016 / 3:58:38 PM] Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00EC00BC00000055005400EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [SAMSUNG] KA100O015B_BJTT [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 DEV RID : F3146F043BE9E7ECD0872B6ECA5A9885 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! flash file reda done ---and write thsi file-Flash-Tool hang and lago samsung-s7582- MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : samsung Device Model : GT-I8262 Device CPU : MT6572 Device IntName : GT-I8262 Device Version : 4.2.2 Device Compile : 10/23/2015 8:16:32 AM Device Project : ALPS.JB3.MP.V1 Device ExtInfo : GT-I8262 |
Could you please explain what is the problem with your phone ? |
-mobile pattern lock problem pattern lock -read error full read file cm2 and flash -SP_Flash_Tool mobile hang and lago mobile samsunge gt-s7582 Start at : [4/4/2016 / 3:59:50 PM] Operation : Read Flash [ v1.44 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 20 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00EC00BC00000055005400EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [SAMSUNG] KA100O015B_BJTT [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 DEV RID : F3146F043BE9E7ECD0872B6ECA5A9885 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_mbk72_wet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6572 / V1.1.1 / mbk72_wet_lca / NAND FW Size : 338 MiB Brand : samsung ProdName : GT-I8262 ProdModel : GT-I8262 Device : GT-I8262 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Android Info saved Scatter saved to : C:\Documents and Settings\gsm-mobile\Desktop\New Folder\MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1 |
MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1 By Tabrez - Download - 4shared - Tabrez Ali THIS FILE id [NAND] : FLASH_VEN : 0x0095 , [SAMSUNG] K9K8G16U0K [NAND] : FLASH_DIE : 00EC 00BC 0000 006A 0056 00EC 00BC [NAND] : FLASH_VEN : 0x008C , [SAMSUNG] KA100O015B_BJTT [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC |
Use 1.43 cm2 write ini prealoder write full buckup post result bro |
allredy chake this options sam problem mobile on lcd blue |
Plz infinity team add this options mobile info FlashIC id show- MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1 this file FlashIC id -NAND] : FLASH_VEN : 0x0095 , [SAMSUNG] K9K8G16U0K [NAND] : FLASH_DIE : 00EC 00BC 0000 006A 0056 00EC 00BC MT6572_NAND_samsung__GT-I8262__GT-I8262__4.2.2__ALPS.JB3.MP.V1 this file FlashIC id [NAND] : FLASH_VEN : 0x008C , [SAMSUNG] KA100O015B_BJTT [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC file sam id FlashIC id change plzzzzzzzzzzzzzz add full info read file show FlashIC id and all mobile allred this 2 file write cm2 no errors writen |
Options for what? If that FlashIC's managed for 128k and 256k IC's - it ok, mobile will die after wrong one. |
nand flash again. different lcd firmware make only blue screen. only correct firmware can revive this phone use sp flash tool. What i like from CM2 is ALWAYS GIVE WARNING ALL PROCESS. SO IF YOU GET SOME ERROR LOG FROM CM2 DONT TRY WITH OTHER TOOL OR SP FLASH TOOL IF YOU DONT HAVE GOOD FIRMWARE. |
@gsmkpk when i get free time i will upload system.img file for u |
backup ur phone safe ur system.img file another place and copy this system file in backup folder from link https://www.4shared.com/file/eWj1otXvba/system.html post result |
