plz help me pinout for SANDS A203???? model : SANDS A203 socket 1x20 mini (like samsung d820) pin 3 = gnd pin 7 = gnd pin 19= gnd pin 20= Vbat can anyone tell me rx tx pins? BR |
plz help for this chineas mobile plzzzzzzzzzzzzzzzzzzzzzzzzzzz |
Here is very important information for you: http:///vbb/showpo...36&postcount=7 |
did anyone help me for this?:( |
Plzzzzzzzzzzz Help Help Sos Sos Sos |
Hello, Please, use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 |
no help plz helppppppppppppppppppppppppppppppppppp |
does anyone try this phone and find 100% pinout ????????????? |
i don't undrstanddddddddddd . no one can help meeeeeeeeeeeeeeeee? |
Here is detailed instruction for you but I don't think it will be so useful due to you simply ignored my previous advices. Anyway, let's try one more time: How to find pinout for unknown model Please, follow instruction exactly like described below In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model: 1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location) 2. find Charge pins (it's optional step, just to save your time during future research) 3. find +Battery pins (it's optional step, just to save your time during future research) 4. connect cable Gnd to phone Gnd 5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone 6. if flash read procedure can start this means that pinout found Ok and you can make other operations Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models" it's good idea to find correct pinout according to above instruction and send new pinout information with full text from phone back label to [email protected] |
