Old 05-14-2008, 19:39   #1 (permalink)
Member: 25067
Thanks Meter: 81
How to solve signal problem ???
i've format my phone which have 2 cpu inside without make backup of eeprom and i even not notice that i've format 6205 or 6226 cpu, now all i have sim1 cannot registering to network only emergency but sim2 work ok, i already write imei1 and imei2 but still no luck also make repair security for both cpu, please any suggestion???
Old 05-14-2008, 21:07   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if you did not notice what you did or what was original software version-
you always can find all operations list in file named "operation.log"
regarding your problem i can advice to try all IMEI writing methods for first CPU.
each time check by *#06#
also make sure that IMEI which you writing is not blacklisted
Old 05-15-2008, 09:30   #3 (permalink)
Member: 25067
Thanks Meter: 81
i already try write imei with mode1, 2 and 3 but stoll no luck and unfortunately my operation log is gone
Old 05-15-2008, 09:34   #4 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
try to write eeprom ...............
Old 05-15-2008, 11:34   #5 (permalink)
Member: 25067
Thanks Meter: 81
write eeprom/??? from where???
Old 05-15-2008, 14:54   #6 (permalink)
Member: 148515
hello!
post your software versions for both CPUs- lets see what we have for this phone
Old 05-15-2008, 16:34   #7 (permalink)
Member: 25067
Thanks Meter: 81
thanks sir for fast reply by the way i finally solve my problem after write eeprom fix that i get from infinity support thanks again
I how to solve this problem Saulcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-30-2010 10:02
How to solve this problem ? [Problem] amar181 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 11-25-2009 15:00
Your security card going to expired soon.How to solved this problem hajji1 Cyclonebox 1 11-05-2009 17:05
"Please connect Smart-Ñlip assigned to this S-Card" how to solve dis problem......... rosan Smart-Clip 2 01-27-2009 13:34
how to solve this problem Jazzy x1x to x45/x50 15 07-29-2001 20:18
Page generated in 0.16129 seconds with 10 queries
