plz help qmobile i2 user code Card found: S/N : 3F39398A , v0130 Chinese Miracle II [SPD module] v 1.16 Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Open Port Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Open Port Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Open Port Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:29 Reconnect Power/Cable! |
Hello, Select correct cpu type, can also try with Alternative LDR Mode. If still not works then need to select pac file. Br. Infinity Box Support Team. |
If no luck - Reset in SVC. |
info and code reset done with svc mode Card found: S/N : 3F39398A , v0130 Chinese Miracle II [SPD module] v 1.16 Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_W15.42_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 10-27-2015 15:14:45 Phone Security Info : IMEI [1] : 358334070101366 IMEI [2] : 358334070101374 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.918 V Done Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.16 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... Normal Mode init Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:03 Reconnect Power/Cable! but cannot read file Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:10 Reconnect Power/Cable! |
