Old 04-09-2016, 11:45   #1 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 133
plz help qmobile i2 user code
Card found: S/N : 3F39398A , v0130
Chinese Miracle II [SPD module] v 1.16
Operation : Read FullFlash [ v1.16 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 27 ]
Open Port Failed!
Reconnect Power/Cable!
3. Insert cable
Phone found! [ 27 ]
Open Port Failed!
3. Insert cable
Phone found! [ 27 ]
Open Port Failed!
3. Insert cable
Phone found! [ 27 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Loader start failed! Wrong Model selection!
Boot failed!
3. Insert cable
Phone found! [ 27 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x eMMC v2.0 Loader Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Unknown structure detected! Something went wrong
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:29
Old 04-09-2016, 15:03   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Hello,
Select correct cpu type, can also try with Alternative LDR Mode.
If still not works then need to select pac file.
Br.
Infinity Box Support Team.
Old 04-09-2016, 15:17   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,635
If no luck - Reset in SVC.
Old 04-10-2016, 08:14   #4 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 133
info and code reset done with svc mode
Operation : Check/Read Info [ v1.16 ]
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 15 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_W15.42_Debug
Project : sc7731g_CP0_modem
HWInfo : sc7731g_CP0_modem
Compile : 10-27-2015 15:14:45
Phone Security Info :
IMEI [1] : 358334070101366
IMEI [2] : 358334070101374
BT_ADDR : 000000000000
SelfInfo :
BatVoltage : 3.918 V
Done
Operation : Format File System / Reset Settings [ v1.16 ]
Settings : SmartFormat is On
2. Insert cable
Phone found! [ 15 ]
Port Opened
Sync...
Normal Mode init
Sync...
Init Ok , reset settings ...
Format Ok!
Done
Elapsed: 00:00:03
but cannot read file
3. Insert cable
Phone found! [ 27 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:10
Page generated in 0.23906 seconds with 7 queries
