10-11-2006, 10:15 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: CANADA Age: 42
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | plz help in ST60 in flashe i have a boot ok but in error after this boot plz help ?? COM1 selected Device: Siemens ST55,ST60 Checking data, wait... Action: Flash write "SmartWrite" enabled Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Err: Boot failed: Release Power button ! Err: wrong answer1 Boot Fail Finished Remove/Install battery now ! Time used: 9 sec |
10-11-2006, 10:25 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | According to your log here is possible problems: 1. charge battery. 2. check your cable and com port selection. 3. check phone hardware. that's all. |
10-11-2006, 10:32 | #3 (permalink) |
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | thanx mister for the cable and the battrie are all ok but I think has to decontaminate the pile of memory of my telephone and to test afterwards |
10-11-2006, 10:35 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | you must make the next procedure first: 1. charge battery. 2. check your cable and com port selection. 3. check phone hardware. as you can see from log file your phone can't communicate with software. Please, don't ignore my advices and make all step by step: 1., 2., 3. after this you will see good results. |
10-11-2006, 12:08 | #6 (permalink) |
No Life Poster Join Date: Aug 2004 Location: dasma cavite Age: 46
Member: 78367 Status: Offline Thanks Meter: 11 | COM4 selected Device: Siemens ST55,ST60 Checking data, wait... Action: Flash write Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 98007400000002 Flash: 8CE59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Firmware area requested/selected: 01/01 Write: Map/Customization area requested/selected: 02/02 area requested/selected: 02/02 area requested/selected: 02/02 Write: Language Pack area requested/selected: 01/01 Write Done Finished Remove/Install battery now ! Time used: 1058 sec sample flashing of st55 today, it is dead after flashing it phone is alive. |
Hi respectable Engeers plz help in ........ | chohansahib | iPhone 2 / iPhone 3G / iPhone 3GS | 17 | 03-31-2010 18:57 |
plz plz help in unlocking k800i | med26 | Sony Ericsson | 1 | 02-11-2010 21:37 |
plz help in unlocking in sando s330 | eswar7983 | Various | 0 | 07-11-2008 11:28 |
To Bert &wazl and all moderators&members plz help in be1 | Mr.Fl@sher | Alcatel & TCL Old Models | 9 | 04-18-2004 07:50 |
plz help in installing mstools 2000 | monti_908 | Mitsubishi | 4 | 02-10-2003 06:21 |
