11-03-2009, 08:58 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 594019 Status: Offline Thanks Meter: 46 | Plz infinity team help http://forum.gsmhosting.com/vbb/showthread.php?t=781621 after several tries, and research on this strange problem, I think I got an important result. it is better explained on the image. What's a wrong plz? |
11-03-2009, 20:21 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! probably your main infinity box has some errors on PCB. (some components missing or else) try to set pull_up resistors on tx & rx and check again |
11-04-2009, 16:03 | #4 (permalink) | |
Member: 594019 Status: Offline Thanks Meter: 46 | Quote:
This is a pcb pictures, plz help | |
11-04-2009, 21:23 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you dont have to change anything. just add "pull_up" resistors to tx and rx pins. one resistor side solder to +5v, another to Tx another resistor solder one side to +5v andother to Rx this will pull up signal and might be box will more clear see signals. value of resistor you can find in tests |
11-05-2009, 17:03 | #6 (permalink) | |
Infinity team is the best | |
11-07-2009, 18:08 | #8 (permalink) |
Member: 594019 Status: Offline Thanks Meter: 46 | I maked just one resistor=36 kohms at TX because voltage at RX is good=5V and with this the TX < 5V but work good, Now it detects all phones supported. Last edited by lucky_gsm; 11-07-2009 at 18:18. |
The Following User Says Thank You to lucky_gsm For This Useful Post: |
Pzl plz plz infinity team help me....... | abid dar | Infinity-Box | 1 | 05-06-2009 19:43 |
Plz infinity team help me.. | abid dar | Infinity-Box | 1 | 11-04-2008 19:11 |
plz infinity team help me | robin25 | Infinity-Box | 1 | 08-26-2008 14:43 |
plz infinity team help me in dide n99i 2 serial after flash fone | KhOliO | Infinity-Box | 4 | 07-08-2008 00:03 |
plz infinity team help me in dide n99i 2 serial after flash fone | KhOliO | Infinity-Box | 2 | 07-06-2008 20:40 |
