03-28-2008, 09:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: United Kingdom
Member: 109729 Status: Offline Thanks Meter: 36 | Problem with N95 2 sim slider original firmware is NLJ26_06A_PCB01_GPRS_MT6226_S01.MT6226_S01_MAUI_06 B_W07_04_MP_V3.BIN I tryed format safe and complete, and write imei. Not work, same problem. I flashed with CM_Nokia-N95-2sim_NLJ26_06A_PCB01_GPRS_MT6226_S01.N95_4B0_BYD77 87_OV_BT_RUSSIAN_FRENCH_ARABIC_ENGLISH_2_5_16m_En_ Ru_Fr_Ar.B0M format, write imei. At first phone see both sims but can call from second sim, but display not calibrate. After calibrate imei and factory reset phone don't see again second sim.. Wich firmware or what can i do pls... Anny help is appreciated |
03-28-2008, 11:48 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must use match to your original version flash file. NLJ26_06A_PCB01_GPRS_MT6226_S01.MT6226_S01_MAUI_06 B_W07_04_MP_V3 there is a lot of different flash files with many languages on support just make search at bottom of page: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
03-28-2008, 15:08 | #3 (permalink) |
Member: 109729 Status: Offline Thanks Meter: 36 | I do that and is not on suport area.... same like this flash : E553AGENT_F1_E553_GSM_MT6205B_DN.01_5.BIN i need this too, i have 3 pcs of n N5 dual sim (not slide) wbr |
03-28-2008, 20:23 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! here is flash files which you requested in first posting: flashfiles/ChineseMiracle/_MT6226/CM_Nokia-6500-2sim_1x12pin_NLJ26_06A_PCB01_GPRS_MT6226_S01.MT622 6_S01_MAUI_06B_W07_04_MP_V3_16m_En_Ru_Fr_Th_Vn_Ar. B0M.bin flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N73-CPU1_2x6pin_NLJ26_06A_PCB01_GPRS_MT6226_S01.MT6226 _S01_MAUI_06B_W07_04_MP_V3_16m_En_Ru_Fr_Th_Vn_Ar.B 0M.bin here is flash files for second post: flashfiles/ChineseMiracle/Anycool/Anycool-D66+_CPU2_E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_ 1__E553AGENT_F1_E553_GSM_MT6205B_DN.01_5_4m_En.B0M .bin flashfiles/ChineseMiracle/_MT6205/CM_Cect-T689-CPU2_E553AGENT_F1_E553_GSM_MT6205B_DN.01_5_4m_En_w _eep.B0M.bin please note that second flash file which you requested is CPU2! flashing it will not help if phone restarts |
I Face Common Problem In N95 2 Sim Slider | chiragsp_codes | Infinity-Box | 4 | 11-23-2007 10:43 |
