02-10-2016, 08:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 681959 Status: Offline Thanks Meter: 106 | Port Opened Sync... Initial Boot Failed! 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 47 ] Open Port Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Boot Files missing! Select SLDR or PAC file! Boot failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 47 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
02-10-2016, 08:13 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, What is phone model? Without phone model/ cpu detail how can we help? Anyways, try with all boots one by one if you don't know cpu inside. Also try with Alternative LDR mode or selct SLDR manually and then connect phone. Br. Infinity Box Support Team. |
02-10-2016, 09:03 | #5 (permalink) |
Member: 681959 Status: Offline Thanks Meter: 106 | 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : hy801a_intex Model Brand : intex Model Device: hy801a_intex AndrVersion : 4.4.2 BaseBand CPU: HY801A_HD Project Ver : Intex_AquaStarIIHD_V06_India_SER Model Ext : Aqua Star II HD [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_w.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.13_Release.bin [Read Ok] : logo_720x1280.bin [Read Ok] : fblogo_720x1280.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 940 MiB Saved to : C:\Users\raju\Desktop\HY801A_HD_hy801a_intex_4.4.2 _Intex_AquaStarIIHD_V06_India_SER\ Done! Elapsed: 00:07:49 Reconnect Power/Cable! |
The Following User Says Thank You to alkesh02 For This Useful Post: |
02-26-2017, 14:50 | #7 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2437379 Status: Offline Thanks Meter: 1 | CPU SPD6531...... how to solve i just try to read user code Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 51 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 51 ] Open Port Failed! Reconnect Power/Cable! Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 51 ] Open Port Failed! Reconnect Power/Cable! |
02-27-2017, 13:00 | #9 (permalink) |
Member: 2437379 Status: Offline Thanks Meter: 1 | How to remove Q mobile L1 classic password / User code i've solve the issue SPD cpu.... why initial power failed why open port failed why give boot error why device not synced here's the solution |
The Following User Says Thank You to UsamaKhan For This Useful Post: |
