11-04-2009, 13:31 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | Is it possible to unlocked hi messenger china phone using infinity? here is the logs COM4 [VCP0] selected module v2.95 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F703:0001 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! pls help urgent |
11-04-2009, 19:39 | #4 (permalink) |
Member: 153893 Status: Offline Thanks Meter: 266 | Sucessfully unlocked it,thank u infinity team for ur great work COM4 [VCP0] selected module v2.92 Device: AT-Telecom-Hi-Messenger Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F703:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.T500_DUTC H_PR_R0_2_V8_0.BIN ver. sw 2: T500.DUTCH.PR.R0.2_V8.0, 00000000 address offset: 00000000 ffs offset/size: 01C00000/00400000 ffs address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: AT-Telecom-Hi-Messenger_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00 .T500_DUTCH_PR_R0_2_V8_0__ffs... file saved: C:\Program Files\InfinityBox\MModule\AT-Telecom-Hi-Messenger_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00 .T500_DUTCH_PR_R0_2_V8_0__ffs_20091104-182126.B0E.bin flash: 01227E223C2200:0AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done Special operation ... detecting parameters to apply patch area 1... ....... required data found flash: 01227E223C2200:0AEA0000000000 flash: 01227E223C2200:0AEA0000000000 Write: area 1 (pass 1) .................................................. .................................................. ..................... area 1 patch applied Ok Special operation Done Write ... flash: 01227E223C2200:0AEA0000000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 885 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to godwin For This Useful Post: |
06-03-2010, 18:25 | #5 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Mediteranean
Member: 59352 Status: Offline Thanks Meter: 50 | COM36 [VCP0] selected module v3.39 Device: AT-Telecom-Hi-Messenger Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9D03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.T500_DUTC H_PR_R0_2_V8_0.BIN project-id: T500.DUTCH.PR.R0.2_V8.0, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/00400000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E223C2200:0AEA0000000000 Backup required data Done ====> Patch required data ... .................................................. ........... lock area found .................................................. ........... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ....... required data found flash: 01227E223C2200:0AEA0000000000 flash: 01227E223C2200:0AEA0000000000 Write: area 1 (pass 1) .................................................. .................................................. ..................... area 1 patch applied Ok Special operation Done ====> Write ... flash: 01227E223C2200:0AEA0000000000 flash: 01227E223C2200:0AEA0000000000 Write: lock-area-1 flash: 01227E223C2200:0AEA0000000000 flash: 01227E223C2200:0AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 47 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to alknadir For This Useful Post: |
Is it possible to unlock this SKY model with Infinity? | chrisonic | Infinity-Box | 4 | 07-24-2009 13:56 |
B500 is it possible to unlock thru 7.21 ver? is this phone supported??? | ReyTech | UST Pro II | 4 | 09-26-2008 11:20 |
707scII 02.2008 v1.3 chaiman2...is it possible to unlock using USTpro2 | richardnikko | UST Pro II | 3 | 07-19-2008 19:20 |
Is it possible to unlock P906 using NS-Pro? | UnlockBR | NSPRO | 2 | 03-02-2007 22:25 |
