08-05-2015, 15:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Post successful Direct Phone Book extraction of MTK CPU Chinese Miracle II [MTK module] v 1.25 Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010051385853414206D287CC36B1F7 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX8 [eMMC] : FLASH_CID : 15010051385853414206D287CC36B1F7 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 2508 TXT Saved to : C:\Documents and Settings\Administrator\Desktop\MT6592_PhoneBook.tx t Write : 2508 CSV Saved to : C:\Documents and Settings\Administrator\Desktop\MT6592_PhoneBook.cs v Write : 2508 Done! Elapsed: 00:00:30 Reconnect Power/Cable! Model Geonee S5.1 , Display broken |
08-05-2015, 16:01 | #2 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | MI note - Hang on logo Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483847326404050196389561BD DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A483847326404050196389561BD [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 1090 TXT Saved to : C:\Documents and Settings\Administrator\Desktop\MI Note\MT6592_PhoneBook.txt Write : 1090 CSV Saved to : C:\Documents and Settings\Administrator\Desktop\MI Note\MT6592_PhoneBook.csv Write : 1090 Done! Elapsed: 00:00:49 Reconnect Power/Cable! |
08-05-2015, 16:14 | #3 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Micromax A117 ( Digitizer damaged ) Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019064314734A201860457703219 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A219327057 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 1 TXT Saved to : C:\Documents and Settings\Administrator\Desktop\A117\MT6583_PhoneBo ok.txt Write : 1 CSV Saved to : C:\Documents and Settings\Administrator\Desktop\A117\MT6583_PhoneBo ok.csv Write : 1 Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following User Says Thank You to srinibas For This Useful Post: |
08-05-2015, 16:18 | #4 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | K Touch M301 ( Phone Lock ) PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 65F1611B44B03C8E8F2CB8EE8D4A6D11 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Step #1 Step #2 Read Ok, PhoneBook records extracted : 251 TXT Saved to : C:\Documents and Settings\Administrator\Desktop\M301\MT6260_PhoneBo ok.txt Write : 251 CSV Saved to : C:\Documents and Settings\Administrator\Desktop\M301\MT6260_PhoneBo ok.csv Write : 251 Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
08-06-2015, 03:30 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Lenovo A369i \ Code: Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D0278FF8827317D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D0278FF8827317D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : A369i ProdModel : Lenovo A369i Device : A369i AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D0278FF8827317D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D0278FF8827317D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 47 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook_lenovo.txt Write : 47 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6572_PhoneBook_lenovo.csv Write : 47 Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
08-06-2015, 09:23 | #6 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | XOLO A550s IPS Read Phonebook Done Code: Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201D5E7CC447193 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201D5E7CC447193 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 80 TXT Saved to : C:\Users\Desktop\MT6572_PhoneBook.txt Write : 80 CSV Saved to : C:\Users\Desktop\MT6572_PhoneBook.csv Write : 80 Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to ishant For This Useful Post: |
