12-14-2008, 13:11 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | ***** ke850 unlocked module v1.58 Device: LG-KE850 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static_20081215-170835.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static2_20081215-170835.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-security_35030526000000100_20081215-170837.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_35030526000000100_20081215-170840.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 18257914 Finished, time used: 21 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to NADEEM GONDAL For This Useful Post: |
12-14-2008, 13:49 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @NADEEM GONDAL Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Lg ke850 ***** sucessfully unlocked by infinity-box:)- | sahil2000ind | Infinity-Box | 8 | 10-21-2009 22:39 |
Problem Unlock Lg ***** Ke850... | BABAK NURI | MT-BOX | 0 | 12-01-2007 11:55 |
problem of unlocking LG ***** KE850?? | Jamal | LG | 2 | 11-21-2007 23:57 |
a problm with LG ***** KE850 unlocking | Jamal | FuriousGold | 2 | 10-10-2007 15:40 |
can i unlock lg ***** ke850 | speedstarrr | HWK | 4 | 09-01-2007 17:57 |
