Old 11-14-2015, 10:57   #1 (permalink)
Member: 49737
Thanks Meter: 7
preloader repair
Hello I want to repair preloader
My error is
Error : DA init Failed! Error code : 0x5
LErr : EMICFG_NOT_FOUND
How to repair this?
Old 11-14-2015, 11:25   #2 (permalink)
Member: 49737
Thanks Meter: 7
Wait for phone...
Phone found! [ 51 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6752
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6732|MT6752_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 150100513732534D4200DB41808A52D5
DA Stat : v4.2 on BBID : 0x8F
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00B0
Boot Error!
Old 11-14-2015, 11:26   #3 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 278
Hi team
also need to restore the tablet
Operation : Flash Erase [ v1.36 ]
User accepted Flash Erase operation!
Wait for phone...
Phone found! [ 15 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
eMMC_ID : 8801034E436172642035154785441141
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0088 , OEM : 0103
[eMMC] : FLASH_INF : draC
[eMMC] : FLASH_CID : 8801034E436172642035154785441141
[eMMC] : FLASH_EXT : 00200000/00000000
[eMMC] : FLASH_LEN : 0x00000001CE100000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Erase whole flash
Flash erase done
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
User selected Preloader file : preloader_mbk82_tb_kk.bin
Start at : [13.11.2015 / 14:41:34]
Operation : Init Preloader [ v1.36 ]
Wait for phone...
Phone found! [ 23 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
DRAM EmiReq Ok , 0x00BC
DRAM Init Ok , 0x02000000
DA start Failed at final stage!
Check battery , cable , drivers and try try again
Boot Error!
Operation Failed
Elapsed: 00:00:13
Operation : Flash [ v1.36 ]
======= Flash
Wait for phone...
Phone found! [ 23 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:12
Old 11-14-2015, 11:50   #4 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 346
Originally Posted by xerx View Post
Wait for phone...
Phone found! [ 51 ]
Sync...
Boot Info :
BB_CPU_ID : 6752
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
Boot Error!
Mate for repairing Preloader just go Extra tab click on Init Preloader select preloader file or full bin file Specially for MTK6575 and MTK6577 you have to select full bin file .After repairing preloader flash it by its bin firmware your phone will turn on if you have chosen correct preloader and bin file.
Old 11-14-2015, 15:42   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,059
I can't help, if before not made FW backup. It allow repair, if something goes wrong.
Old 11-16-2015, 06:49   #6 (permalink)
fazal subhan's Avatar
Member: 235459
Sonork: 100.1669756
Thanks Meter: 33
preloader status not alive (erased)
qmobile x90 mtk6572 dead with wrong scatter. after dead boot repair with test point jumper .now with this err preloader status not alive (erased) pls help me.
Old 11-16-2015, 12:32   #7 (permalink)
JayDi's Avatar
Member: 462970
If you make over9000 posts it will change nothing. Now seek answer.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-16-2015, 13:51   #8 (permalink)
Member: 1199392
Thanks Meter: 82
Wait for phone...
Phone found! [ 51 ]
Sync...
Boot Info :
BB_CPU_ID : 6752
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
Boot Error!
bro press volume uo down key your problem 100% done
The Following User Says Thank You to wi fi For This Useful Post:
Old 10-29-2016, 20:36   #9 (permalink)
ranaarshadwaqas's Avatar
Member: 2607003
Sonork: 100.1667344
Thanks Meter: 70
Rehot emmc or replace
HANDSET ALLREADY CONNECTED NO NEED PRESS KEYS
THIS IS HARDWARE PROBLEM
Page generated in 0.28086 seconds with 7 queries
