06-14-2018, 23:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | prestigio 7600 problem Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Prestigio Device Model : MTK6589Turbo Device CPU : MT6589 Device IntName : PAP7600DUO Device Version : 4.2.1 Device Compile : 12/17/2013 3:44:12 AM Device Project : ALPS.JB2.MP.V1.2 Device ExtInfo : PAP7600DUO Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4D6F6465524F4D200100464EF1000000 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! heny help experts?? br |
06-15-2018, 01:36 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Try with stock firmware : PAP7600DUO_20150121.1.1.13 Another found : 20150121.1.1.13 If it's still incompatible - you have phone from Netherlands, which uses different firmware. Post here, I will try to get that one firmware. b.r Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
06-15-2018, 02:18 | #3 (permalink) | |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Quote:
same error sir: Card found : S/N : 8CD632DE , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4D6F6465524F4D200100464EF1000000 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! br | |
06-15-2018, 20:29 | #4 (permalink) | |
Hello sir eny news from other flash files?? Russian file as scatter error.. BR | |
06-18-2018, 15:08 | #5 (permalink) | |
Hello sir Brka...possible to get that rom from Netherlands??? Phone is on same condicion... All the best... br | |
06-19-2018, 01:37 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Download: PAP7600DUO_1.0.12_NL_by_bRkA p.s. Try previous rom also, with flasher from this archive. Read PDF inside - HOW-TO. p.s.2. If still the same - device have hardware problem(s). b.r. ALex
The Following 2 Users Say Thank You to Brka For This Useful Post: |
