08-26-2020, 07:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile dhoom rrio reset password cm2 download flash file free Card found : 73CA70CC , v0145 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.06 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : 354361100453651 IMEI[2] : 354361104453657 Done! Elapsed: 00:00:26 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E7 FC3901104_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Read Flash Ok, Size : 4.00 MiB QMobile Dhoom Trio_v10_20190301 Project Version: SC6531EFM_BAR MMI Version: SC6531EFM_BAR BASE Version: BASE_SVN HW Version: SC6531EFM_BAR 03-01-2019 10:49:00 LOG Version: V1.0.1 UCOM Saved to : H:\Mix Flash File\QMobile Dhoom Trio_v10_20190301.bin Done! Elapsed: 00:00:55 Reconnect Power/Cable! Flash File Link https://www.youtube.com/watch?v=JU-CxWrYS_U |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
09-01-2020, 19:07 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Thanks a lot ! File QMobile-Dhoom-Trio_v10_20190301.7z transferred to Infinity support area |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
