05-08-2016, 14:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1250765 Status: Offline Sonork: NOt Available Thanks Meter: 28 | Prestigo PAP5503 Duo Dead Cm2 Complete Flashing after set not coming On . I Already flash that Model Now Set is dead. |
05-08-2016, 17:08 | #3 (permalink) |
Member: 1250765 Status: Offline Sonork: NOt Available Thanks Meter: 28 | Chinese Miracle II [MTK module] v 1.46 Scatter Load Ok , BaseBand : MT6582 , Project : lcsh82_wet_hz_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.46 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A12C455193 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A12C455193 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 75578E26B9CCDD2A71302C69549A829B INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : lcsh82_wet_hz_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3554 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000A3600000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh82_wet_hz_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:10:46 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:29 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:11:40 Reconnect Power/Cable! |
05-09-2016, 15:57 | #8 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Mobile World Age: 35
Member: 1667884 Status: Offline Thanks Meter: 144 | check sticker under battery ....check software version and download it and flash it then post result .... sometimes some file dos't support because hardware version is deffrent .... |
05-10-2016, 08:22 | #13 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
There are two possible reasons- either eMMC is in RO state or there is change in hardware revision in phone which needs correct flash file. You can also try to full erase (uncheck keep preloader) and flash after. Br. Infinity Box Support Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
07-03-2017, 09:42 | #15 (permalink) |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | this year CM2 MTK is bad no update, try in .... Format Whole Flash first in SPFT then write flash in ...... chk also if the flash file and the phone preloader is match, i encountered it on any clone after flash in CM2 dead even flash success but writing backflash phone alive. Last edited by InfinityHelp; 09-09-2017 at 16:09. Reason: fake advertizing removed |
