Old 01-09-2009, 15:47   #1 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 224
prob with motorola F3 & other
1-i tried to read flash or unlock but error , my cable is tested with ather tools and work perfect.
2- second prob when i used pinfinder with N82 chinese work perfect and detect pin when i open chinese soft the soft can't detect phone , i tryed with chinese phone and ather phone exp SE J132 , i need solution for this or my box not work
Old 01-09-2009, 16:06   #2 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 03335548581
Thanks Meter: 1,607
u must select slow badurate then try
Old 01-09-2009, 16:52   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
1. you must use box RJ45 cable but not COM port cable
2. need to get more details about problem, f.e. logs
Old 01-09-2009, 21:50   #4 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 224
thx for reply
1. you must use box RJ45 cable but not COM port cable : R = same prob with motorla F3 & ather modele
for 2 prob , when i use pinfinder for detect pin (exp phone chinese pin finder work perfect and give me the pin corect but when i open soft chinese phone can't be detect with infinitybox & give me error i think is my infinity box not work beacause with ather soft give me same prob but it work when i use it for univerbox .
Old 01-09-2009, 22:02   #5 (permalink)
limem2003's Avatar
Member: 108627
Thanks Meter: 307
hi
same problem with F3
COM1 [Serial0] selected
Loading data, wait...
Device: F3
Press and Hold Power button...
rom version: 0502
Connecting...
rom version: 0502
booting...
finalizing...
working, one more step...
error: incorrect boot answer-1:
Remove/Install battery now !
Old 01-10-2009, 12:54   #6 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 224
OK, prob solved , now i ask how to flash motorola F3 with infinity because i see in support flash for F3 in soft i can't see how to flash , thx in advance
Old 01-10-2009, 18:00   #7 (permalink)
Member: 130995
@limem2003
Old 01-10-2009, 18:00   #8 (permalink)
Member: 130995
Check "Shell", you will see different model selection for "F3" and 'F3-unlock"
Old 01-10-2009, 23:02   #9 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 224
but i need to flash F3 not for unlock
Old 01-11-2009, 07:32   #10 (permalink)
Member: 130995
so run Shell, select model "F3" and you will see software that can flash "F3"
Old 01-11-2009, 18:23   #11 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 224
thx very match sorry for this , i'm new user in infinitybox
strange prob with some phone & Smti allal123 SMTi 4 11-25-2007 16:48
!!! Motorola F3 (and other models) unlock codes for all UBL clients !!! MANOLE Ultima Box Light 207 09-07-2007 08:53
z140v unlocked but probs with internet settings & mms luvleigh QUALCOMM Models (3G) 2 01-22-2007 21:33
prob with motorola activation NiceLys Dongle Problems (USB-Smart) 9 05-27-2006 14:22
Page generated in 0.20746 seconds with 11 queries
