09-08-2010, 13:46 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Problem IN 2076 VERF DIAG DISABLED UNLOCK !!! module v1.24 Device: Haier-C2076 operation: SP-unlock (DIAG-mode disabled) Phone should be Switched ON ! connecting... Check conection... OK... Sending command... Sending command 30%... Sending command 60%... Sending command 90%... Sending command 100%... Checking version... -j‚°ÐÜ.- different version.. Finished, time used: 15 sec This Set Is verf already unlocking with XXXX unlocker . i m just testing for conformation in infinity cdma tool... The date of set is 08062010... |
09-08-2010, 14:18 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Code: ==== [9/5/2010 8:29:46 PM] ==== COM39 [QCUSB_COM39_2] selected module v1.23 Device: Haier-C2076 operation: SP-unlock (DIAG-mode disabled) Phone should be Switched ON ! connecting... Check conection... OK... Sending command... Sending command 30%... Sending command 60%... Sending command 90%... Sending command 100%... Checking version... -j‚°ÐÜ.- different version.. Finished, time used: 15 sec here is my log's...... but i had not report to infinity...... | |
09-08-2010, 14:36 | #3 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
There Is No Problem In Haier C2076 Version F Diag Disabled This Is Due To two Different dates Phones Running In Market Rite Now We Are Working On This Way As Soon As It Will B Updated Yu All Will Informed Via News Wbr <<<Megatron>>> Last edited by <<<MEGATRON>>>; 09-08-2010 at 14:41. | |
09-08-2010, 16:29 | #4 (permalink) | |
Till then if U are In Hurry Then U Can Download C2076_DiagDisabled_Factory_Flasher_Ver_F.rar from Sendspace.com - send big files the easy way Flasher and flash ur phone In Emergency Mode After that Perform unlock Operation Using SpUnlock Diag Mode Disabled Wbr <<<Megatron>>> | |
09-08-2010, 17:32 | #5 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | I CHECKED IN MORE 2 SET BUT SAME PROBLEM DATE IS 090062010 Code: COM22 [QCUSB_COM22_2] selected module v1.24 Device: Haier-C2076 operation: SP-unlock (DIAG-mode disabled) Phone should be Switched ON ! connecting... Check conection... OK... Sending command... Sending command 30%... Sending command 60%... Sending command 90%... Sending command 100%... Checking version... -j‚°ÐÜ.- different version.. Finished, time used: 15 sec |
09-08-2010, 17:35 | #6 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Another Set Same Date this operation is do without flash 09062010 same date Code: COM22 [QCUSB_COM22_2] selected COM22 not available Abort operation ? module v1.24 Device: Haier-C2076 operation: SP-unlock (DIAG-mode disabled) Phone should be Switched ON ! connecting... Check conection... OK... Sending command... Sending command 30%... Sending command 60%... Sending command 90%... Sending command 100%... Checking version... -j‚°ÐÜ.- different version.. Finished, time used: 16 sec Last edited by PUNEET5154; 09-08-2010 at 17:43. |
09-08-2010, 17:51 | #7 (permalink) | |
yes bro i also telling but infinity-team not accept this ??? why ????? | |
09-08-2010, 18:25 | #8 (permalink) | |
Product Supporter Join Date: Jun 2010
Member: 1319166 Status: Offline Thanks Meter: 1,476 | Problem found and will be fixed soon Quote:
Haier 2076 as you know have lots of version .We have supported Maximum know version till today .Except the one which have slight problem in detecting correct version .Either this is new type haier 2076 version f .We will try to find this 2076 version f new type phone and will support as soon as we have phone in hand . Here is some logs of success report for 2076 version f: http://forum.gsmhosting.com/vbb/f633...abled-1086337/ Solution : 1)flash with factory flasher from support Area if your phone shows some unknown version . 2)wait for update till we found phone and can fix this small problem of detection . wbr | |
The Following 2 Users Say Thank You to Infinity-CDMA For This Useful Post: |
09-16-2010, 09:54 | #9 (permalink) | |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Quote:
When its come sir all r waiting for this running version in market | |
09-16-2010, 10:01 | #10 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: Chennai - India Age: 37
Member: 372320 Status: Offline Sonork: 100.113211 Thanks Meter: 2,661 | Quote:
http://forum.gsmhosting.com/vbb/6308767-post8.html We are working Some Other Cool Option and cool Model right know.. after finished we look in this version Hope you understand Regards Ram | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
