09-30-2007, 22:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Nokia 6300 Dead after formating I have China Nokia 6300 Restarting problum when I formate that with Infinity , software displaed , eeprom address not found Do you want to use standard eeprom address,me press yes. after some time formate complete but phone is dead hear is my log file COM15 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished detecting eeprom area in 1 chip(s)... flash: 98004900000002:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ...... fat location can't be detected eeprom element #1 detection failed error: autodetection failed Finished, time used: 87 sec Remove/Install battery now ! |
10-01-2007, 06:53 | #2 (permalink) |
Super Moderator Join Date: Aug 2000 Location: Malaysia
Member: 1922 Status: Offline Sonork: 100.64645 Thanks Meter: 692 | infinity coder aldy make clear b4...this should help u "ChineseMiracle": How to repair "reboot/restart/freez with SIM card" 1. make full flash backup for emergency case (use 921000 speed for fast operation) 2. select "safe" format method 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone Powered-On if phone Ok go to step-6 if phone still in reboot/restart/freez state: select "complete" format method and go to step 3 if phone can't Power-On: restore original flash backup if you don't have original backup: write different firmware files with firmware version similar to original (make ask/rpl if need) 6. restore original imei 7. if phone has touchscreen LCD make calibration: click to LCD corners one by one if still no luck: check phone hardware Original Link Here br acyl2000 |
10-01-2007, 07:31 | #3 (permalink) |
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | I tried to write eeprom and firmware but not results because when writing start software displaed '' writing erar ,writing erae,writing erar and phone deattach |
10-01-2007, 07:31 | #4 (permalink) |
No Life Poster Join Date: Nov 2005 Location: TANZANIA Age: 47
Member: 202611 Status: Offline Thanks Meter: 51 | dear friend restore eeprom backup by flashing eeprom ur phone will come alive but in same conditon and do format ffs but this time change format mode and select safe mode ur phone will fine |
10-01-2007, 17:21 | #5 (permalink) | |
During eeprom write press "YES" and write eeprom backup to phone. if you see other errors during eeprom write process post log here, but never make screenshot, only post here log txt. | |
nokia 6300 dead after flahing plz help me | nishatmohd | Nokia Hardware & Hardware Repair | 9 | 02-06-2009 19:22 |
Nokia 6300 dead after Bb5box? | xmans | Nokia Hardware & Hardware Repair | 3 | 09-24-2008 05:10 |
Nokia N8 dead after format..... | adnanskyland | SpiderMan | 2 | 08-06-2008 08:04 |
nokia 6300 dead after flashing | HIM | Universalbox | 3 | 07-13-2007 21:51 |
