06-26-2011, 20:02 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Marrakech
Member: 282206 Status: Offline Thanks Meter: 102 | problem after unlock ot355x and lcd becomes black i flash with bin in support but still same problem module v3.92 Device: Alcatel-355X, 355A, 355DA Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A9E7:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.68974121 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_FFB9E707].rpl ==================== New firmware found (v.3.92, database date: 29.05.2011): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 68974121 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 07E7B9FF code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 46E provider: 355X-2CBYFR1 customization: CI46CR85 customization: XI46CR85 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI46CR85 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->087ADEC4 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355X,355A,355DA__system_log_68974121_FFB9E707_2011 0622-202726.B0X.bin Finished, time used: 2 min 6 sec Remove/Install battery now ! |
06-27-2011, 19:58 | #4 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: At the center of the Earth
Member: 851708 Status: Offline Sonork: 1000.2brian Thanks Meter: 15 | Quote:
brother dont worry, after you flash the phone, please just format the phone. after this it will get locked again, then after that if it ask unlock just pm me. | |
06-28-2011, 00:38 | #6 (permalink) |
Member: 282206 Status: Offline Thanks Meter: 102 | hello,thanks for repply i have flashed phone with 2 firmwares (355X-2CBYFR1-46I_XI46CRA3_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2011-01-25_En_Fr_Es_It_De.B0M.bin) +(355X-2AWNIT1-46G_XI46CA81_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2011-01-03_En_Fr_Es_It_De.B0M.bin) and formated it too but still same problem . my problem that i dont make full flash back up it s my fault |
06-28-2011, 16:17 | #10 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 852415 Status: Offline Sonork: 1606874 Thanks Meter: 218 | Flash again, when you finish just format the phone or can be done by press *#+Power at same time, then turn on the phone and all be done!... Works for me 3 times in row |
06-28-2011, 23:53 | #12 (permalink) |
Member: 282206 Status: Offline Thanks Meter: 102 | MR yellowboys i flash phone with another firmaware (355X-2ARGFR1-46I_XI46CBA2_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2011-01-25_En_Fr_Es_It_De.B0M.bin) but still same problem but when i connect chargeur to phone i see battrie charger thank you |
06-29-2011, 14:37 | #14 (permalink) |
Member: 282206 Status: Offline Thanks Meter: 102 | hello mr YellowBoss i use last module her s log ==== [28/06/2011 23:18:16] ==== COM4 [VCP0] selected module v3.96 Device: Alcatel-355X, 355A, 355DA Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 355X-2ARGFR1-46I_XI46CBA2_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2011-01-25_En_Fr_Es_It_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:A9E7:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.68974121 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_F63A8537].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 68974121 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 37853AF6 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 46I provider: 355X-2CBYFR1 customization: CI46CRA3 customization: XI46CRA3 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355X,355A,355DA_JRD23_08A_PCB01_GPRS_MT6223P_S00.M AUI_08A_W08_36_SP1_V34__system_log_68974121_F63A85 37_20110628-231933.B0X.bin Area: Firmware flash: EC240200000000:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CI46CBA2 customization name adjusted customization: CI46CBA2 customization name adjusted customization detected: CI46CBA2 customization: CI46CBA2 flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355X,355A,355DA_JRD23_08A_PCB01_GPRS_MT6223P_S00.M AUI_08A_W08_36_SP1_V34__system_log_68974121_F63A85 37_20110628-232438.B0X.bin Finished, time used: 6 min 1 sec Remove/Install battery now ! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
