Old 01-26-2011, 11:23   #1 (permalink)
Member: 229823
Thanks Meter: 22
Problem alcatel ot-565
Hello,
I have a problem with alcatel ot565. After unlock it can't pass boot logo....just restarting. I have security backup - how can i write back in phone.
here is log:
==== [26.01.2011 12:08:00] ====
COM5 [VCP5] selected
module v3.73
Device: Alcatel-565X
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:B2E6:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:2BEA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.B087F 1A0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN_91149072].rpl
New firmware found (v.3.73, database date: 19.01.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: B087F1A0
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN
project-id: MAUI.08A.W08.36.SP1.V40.F4, 72901491
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: E36
provider: 565X-2ARGRO1
customization: CPE3CC2C
customization: XPE3CC2C
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->088C5CDC
..................security area (sec info, hash) detecting size...
error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-565X__system_log_B087F1A0_91149072_20110126-121107.B0X.bin
Finished, time used: 3 min 4 sec
Remove/Install battery now !
please advise,
thx
Old 01-28-2011, 03:57   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,401
Hello,
please, send C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-565X__system_log_B087F1A0_91149072_20110126-121107.B0X.bin file to [email protected]
Old 02-14-2011, 16:13   #3 (permalink)
Member: 714722
Thanks Meter: 30
sam withe me any solution please
Old 02-22-2011, 11:09   #4 (permalink)
Member: 1155
Thanks Meter: 11
I have the same problem, any solution?
After repaired security, phone alive...but locked.
Regards,
DanV
Old 02-22-2011, 11:46   #5 (permalink)
GFTELECOM's Avatar
Member: 922273
Sonork: 100.1583612
Thanks Meter: 119
this phone is not suported for the moment wait new updat
Old 02-23-2011, 09:13   #6 (permalink)
Member: 229823
Thanks Meter: 22
Regards,
DanV
I wrote flash file from suport and phone came back to life although i don't remember any more if i unlocked it via smartclip or was unlocked after flash.
Old 02-23-2011, 09:51   #7 (permalink)
Member: 1155
Thanks Meter: 11
Indeed, the box you name it, give me the good codes
Regards,
DanV
Old 03-14-2011, 13:44   #8 (permalink)
Member: 456610
Thanks Meter: 19
same problem for me , ot-565 after unlock phone restart
After format, phone alive...but locked
any solution?
Old 03-17-2011, 22:14   #9 (permalink)
Member: 130995
any solution?
Hi,
What MModule version you have used for unlock ?
Old 03-29-2011, 22:19   #10 (permalink)
kasketm's Avatar
Member: 17451
Thanks Meter: 31
Originally Posted by InfinitySupport View Post
Hi,
Same problem ...
With MModule 3.81
Old 03-30-2011, 17:44   #11 (permalink)
Member: 1043909
Thanks Meter: 52,179
Hello,
Please, try this:
For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock:
1. use "MModule" software v3.22 or newer
2. use "Write" button from software "Service" page and write original imei (from phone back label)
3. make "sp-unlock"
Old 04-14-2011, 09:27   #12 (permalink)
Member: 25025
Thanks Meter: 6
Originally Posted by YellowBoss View Post
Hello,
Please, try this:
3. make "sp-unlock"
not work - MModule 3.82
if 1. "sp-lock" 2. "write imei" ... phone alive...but locked.
Old 04-14-2011, 19:38   #13 (permalink)
Member: 1043909
Hi,
1. "imei"
2. sp-unlock again
Old 04-15-2011, 15:20   #14 (permalink)
GFTELECOM's Avatar
Member: 922273
Sonork: 100.1583612
Thanks Meter: 119
always not supported sorry
New firmware found (v.3.82, database date: 31.03.2011):
Old 04-19-2011, 19:00   #15 (permalink)
THE-MAXIMUS's Avatar
Member: 145225
Thanks Meter: 98
unlock done
COM38 [VCP0] selected
module v3.82
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:8733:A00C
status: 01
Boot Done
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.1EDEAC93 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F4.BIN_91149072].rpl
TCL-ID detection...
device-id: 1EDEAC93
rom info ver: 05
version: E36
provider: 565X-2ARGFR1
customization: CPE3CA25
customization: XPE3CA25
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35355004051911
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-565X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V40_F4__system_log_1EDEAC93_91149072_20110 419-175641.B0X.bin
Finished, time used: 8 min 13 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 09:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 16:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Page generated in 0.45812 seconds with 8 queries
