06-05-2008, 11:26 | #1 (permalink) |
Junior Member Join Date: Dec 2005 Location: Belgrade
Member: 212706 Status: Offline Thanks Meter: 3 | Problem with Anycool T808 and Pin Out I need help with Pin Finder. Thing is Pin finder is giving me RX-12 and TX-10 for Anycool T808. Now, with this pin out I can flash, format, change IMEI... But I can't find pin out for second CPU. When I try with pin out RX-9 and TX-7 (this pin out is given in pin out folder>Chinese miracle) nothing is happening. Same thing when trying to format with pin out which is given for 2nd CPU (10-Rx, 6-Tx). Does any one knows what is all about? Best Regards P.S. Bottom line is, I want to format 2nd CPU because I have problem with 2nd SIM... |
06-05-2008, 21:59 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! do you know that to get connection on CPU2 you must hold power button about 1 minute. keep it pressed even if phone swith On. Only after phone will completly started- you will get CPU2 connected. In other words- dont panik when phone switch On- this is starting First MCU part. Keep button pressed- and you will get connection |
06-06-2008, 13:40 | #5 (permalink) |
Member: 212706 Status: Offline Thanks Meter: 3 | Thank you for your help! I have managed to format CPU2 (thanks to you ), I used RX-6 and TX-10 but in this way only works when I check "pin reverse" in Pin-Finder. But now I have another problem. A lot of them are not powering up, they start to power and in power up screen they goes off. So, I'm confused again... Do you have any idea? Best Regards |
The Following User Says Thank You to Bela_Zmija For This Useful Post: |
06-06-2008, 13:44 | #6 (permalink) | |
Member: 212706 Status: Offline Thanks Meter: 3 | Quote:
06-06-2008, 13:52 | #7 (permalink) | |
06-06-2008, 15:29 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if phones are not powerable On from box power- you must set capacitor: http:///vbb/showpo...3&postcount=20 |
pinout Anycool t808 20 pin | ziadi_alaeddin | Infinity-Box | 1 | 11-20-2010 12:48 |
Anycool T808 12 Pins | dvb_gsm | Infinity-Box | 2 | 03-08-2009 22:23 |
anycool t808 and 818 | cyngiel | Infinity-Box | 3 | 10-19-2008 12:49 |
HELP:cable schmatics and pin out gd52/92/92 | gsnbhagawan | Panasonic | 0 | 03-18-2001 08:12 |
I NEED GD 30 SCHEMATICS and pin-outs working 100% .. SEND ME IT PLZ | makona | Panasonic | 4 | 10-09-2000 22:56 |
