Unlock Server
Old 04-05-2010, 14:11   #1 (permalink)
Member: 770791
Sonork: Nick
Problem with Beyon B555
I have some problm every I try to reset Beyobd B555...
I used Pana01 V1.76...
COM7 [VCP5] selected
module v1.76
Device: Beyond-B555
Checking data, wait...
Action: reset settings ("format ffs")
Boot ...
e-gold: 820000
loading...
next part...
error: can't run main loader:
Finished, time used: 4 sec
Remove/Install battery now !
try to other baudrate, still same...
Please Infinity Team solution...
Old 04-05-2010, 14:15   #2 (permalink)
YellowBoss's Avatar
Member: 1043909
Hello,
Try to use another cable, f.e. ordinary COM port cable but not FTDI Unibox.
Also, you can try to adjust port settings:
Old 04-05-2010, 14:56   #3 (permalink)
Member: 770791
Sonork: Nick
i use cable infinity stndard, becose pinout rx,tx in board,and i solder cable to pinout dircte..... i use infy com port..
Old 04-05-2010, 15:24   #4 (permalink)
YellowBoss's Avatar
Member: 1043909
Yes, I know.
But as per our experience, in some cases if phone can not be connected well it's good idea to try to use another cable (f.e. ordinary COM port cable or Prolific based USB-RS232 converter.
Old 04-05-2010, 18:45   #5 (permalink)
Member: 770791
Sonork: Nick
Originally Posted by YellowBoss View Post
Yes, I know.
ok.. i will try again... thank for fast support reply...
Old 04-06-2010, 06:35   #6 (permalink)
Member: 770791
Sonork: Nick
Hello,
Thanks infinity team, beyond sucsessfully reset,..
COM4 [VCP4] selected
module v1.76
Device: Beyond-B555
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: .00 ULC2GL 0 A 0 q
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: o:\Infinity Box\software\Pana01\Beyond-B555_eeprom-static_20100406-122908.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: o:\Infinity Box\software\Pana01\Beyond-B555_eeprom-security_20100406-122908.B1E.bin
reading eeprom-complete...
file saved: o:\Infinity Box\software\Pana01\Beyond-B555_eeprom-complete_20100406-122909.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 20 sec
The Following User Says Thank You to Jatnick For This Useful Post:
Problem with OTP!!! THE S3500 josesu Z3X-Team Products 2 07-27-2011 19:14
Problem with j750,,,?? leboss Z3X-Team Products 9 04-16-2010 09:55
Beyon B555 Maybe got some bugs torpedo_seluler Infinity-Box 1 07-07-2008 11:46
Strange problem with 6101 phone! swtichin on with cable but not with battery??? ReyTech Nokia Hardware & Hardware-Repair Area 0 08-01-2006 14:06
.: Strange Problem with T610 power on with p-supply but never with battrey :. Jani-Jan Sony Ericsson Hardware Repair Area 5 05-25-2004 16:31
Page generated in 0.31292 seconds with 11 queries
