06-20-2017, 06:49 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: IR
Member: 2575029 Status: Offline Thanks Meter: 122 | problem boot y336-u02 i need flash or nvram Code: SLDR Load Ok BB CPU : SC7731 Huawei Y336-U02 (Y3C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
10-09-2017, 11:27 | #5 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | you need just to choose the correct flash file so you can grab the correct loder , the flash version you can get it from the recovery mode |
The Following User Says Thank You to f164 For This Useful Post: |
11-15-2017, 09:48 | #6 (permalink) | |
Member: 2575029 Status: Offline Thanks Meter: 122 | Quote:
add pac file with cm2 but cannot boot this phone. old phone and old security or boot cm2 supported. new phone and new security or boot not supported yet.. | |
The Following User Says Thank You to gsm-ok For This Useful Post: |
