Old 04-09-2010, 13:43   #1 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
Problem with chinese Vertu
Hi!
I've an Ascent RM267v (Ferrari) in hands. I've tried to find its pinout using pinfinder, but the phone makes beeps (sometimes) when using pinfinder, and the software can't detect its pinout. Of course, I tried to deactivate power-on sounds (well, the phone vibrates ALWAYS when it's turned on, and it can't be deactivated). But I can power on the phone plugged to pinfinder, so I think that it isn't the problem.
I've found that you've this pinout in pinfinder list, so I've selected it (I though: well, I can't find the pinout by myself, but they did it.. great!). But I'm trying to read fullflash in chinesemiracle software, and it isn't possible. The phone isn't detected. I've tried also inverting pins, changing TX to RX and viceversa, and I wasted my time.
I hope you can help me.
Best Regards,
Old 04-09-2010, 14:20   #2 (permalink)
foufou34's Avatar
Member: 695274
Thanks Meter: 814
if your phone power on you can detecte pinout easy only with multimetre.......................
Old 04-09-2010, 14:22   #3 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
Tell me how, mate. It has the connector as Samsung E250 (12 pins).
Old 04-10-2010, 07:31   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sometimes phone makes sounds while pinout search.
just ignore this and wait pinout search end.
if phone can be powered On from box power- pinout has to be found.
Increase finder activation tries to "20" and repeat search
Old 04-10-2010, 17:31   #5 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
I did it all you said, but no success..
Log:
software version: 1.20
cable type: 1x12 (L12C)
platform: MT: MT62xx (autodetect)
searching adapter at COM8...
adapter found, version: 2000
pins: 12, plain
power cycles: 3
activation cycles: 20
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
failed to detect pins
time required: 358 sec
Trying to Power-On...
Power On !
Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries")
Best Regards,
Old 04-10-2010, 17:44   #6 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
Another try, with CPU independent option:
platform: CPU independent (autodetect) algorithm
pins: 12, plain
power cycles: 3
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
Phone should be Powered-On !
Power-On phone now and press "Ok"
Be sure that phone is not in sleep mode during pinout detection !
Press any phone key from time to time to wake-up phone.
detecting pins...
time required: 547 sec
Old 04-10-2010, 18:16   #7 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
OK I did some investigation:
CPU is MT6225. RX 4, TX5 (I found pinout by disassembling its original datacable).
I'm trying to read its fullflash with infinity, but no way!
Log:
COM8 [VCP0] selected
module v3.11
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 3 sec
Remove/Install battery now !
It only recognizes the phone if I try with it's battery. Powering the phone with pinfinder, it does nothing.
Old 04-10-2010, 18:48   #8 (permalink)
foufou34's Avatar
Member: 695274
Thanks Meter: 814
view shipe type is supported or not or spreadtrum or what..........................................
Old 04-12-2010, 09:01   #9 (permalink)
Member: 148515
hello!
original cable is USB, its pinout is not suitable for flashing.
please check what CPU type is used in this phone.
its probably not MTK
Old 04-12-2010, 19:43   #10 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
Hi!
It's an MT6225 CPU... so it's MTK Also, when I type *#0044# + CALL, it says that phone is set to english.
Old 04-13-2010, 09:33   #11 (permalink)
Member: 148515
hello!
For extra surety you can check pinout in L12C by measuring voltage on system connector pins.
if you fail again- look for test points on PCB
Old 04-22-2010, 10:26   #12 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
Hi!
I looked at PCB test points, and I found TX, RX, GND, VBAT and ON.
Following Infinity Box pinout (1 VCC, 2 TX, 3 RX, 7 & 8 GND) i've soldered my cable directly at these points. I've solder PIN2 (TX) to TX point. PIN3 (RX) to RX point. PINS 8 & 9 (GND) to GND point. It didn't worked, Infinity can't detect the phone. At last, I tried soldering PIN1 (VCC) to VBAT point, so I can try without battery. But that doesn't helps.
Any idea?
Old 04-22-2010, 21:41   #13 (permalink)
Member: 148515
hello!
this is common mistake.
pin2 TX must be connected to phone RX!
and otherwise pin3 RX goes to phone TX
Old 04-23-2010, 08:51   #14 (permalink)
NeTRaW's Avatar
Member: 42553
Thanks Meter: 23
OK problem solved! Maybe TX and RX signals aren't in the phone connector (I suppose). But I can work with PCB test points.
Thank you a lot for your help!
Best Regards,
Old 04-23-2010, 09:31   #15 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
Find Rx .tx Signles easyyy
HOW TO FIND RX .TX SIGNLES .
It is tasted and also you can test it.
1 step is, we need to find GND from phone.
2 step is, we should power on phone (operation with dead phone:
phone must be 100% dead by software)and take multimater put it to voltage.
3 multimeter (-) line put it GND and with (+) line check each connectors
, and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v
(it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v)
This way is too easy and you will save a more time.
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.20234 seconds with 9 queries
