05-14-2009, 00:16 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: in my h.d.d
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | Calibrate touchscreen probleme COM4 [VCP0] selected module v2.82 Action: touchscreen calibration mode: 1 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BA1B:7BAA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: T008_C7_VI_H4S9_071107 Version: T0084.0 detecting structure #2... 0 done 44 byte(s) read imei: 35931703412769 connection Ok detecting structure #5 (mode-1)... done 158 byte(s) read writing data... verification... error: verification failed Finished, time used: 13 sec Remove/Install battery now ! |
05-14-2009, 00:17 | #2 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | MODE 1 REVERSE COM4 [VCP0] selected module v2.82 Action: touchscreen calibration mode: 1 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BA1B:7BAA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: T008_C7_VI_H4S9_071107 Version: T0084.0 detecting structure #2... 0 done 44 byte(s) read imei: 35931703412769 connection Ok detecting structure #5 (mode-1)... done 158 byte(s) read writing data... verification... error: verification failed Finished, time used: 13 sec Remove/Install battery now ! |
05-14-2009, 00:19 | #3 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | COM4 [VCP0] selected module v2.82 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BA1B:7BAA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: T008_C7_VI_H4S9_071107 Version: T0084.0 detecting structure #2... 0 done 44 byte(s) read imei: 35931703412769 connection Ok detecting structure #5 (mode-2)... 1 2 3 4 6 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! |
05-14-2009, 00:20 | #4 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | COM4 [VCP0] selected module v2.82 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BA1B:7BAA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: T008_C7_VI_H4S9_071107 Version: T0084.0 detecting structure #2... 0 done 44 byte(s) read imei: 35931703412769 connection Ok detecting structure #5 (mode-3)... 0warning: wrong packet cs 1warning: wrong packet cs 2 3 4 5warning: wrong packet cs 6warning: wrong packet cs 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! |
05-14-2009, 00:22 | #5 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | COM4 [VCP0] selected module v2.82 Action: touchscreen calibration mode: 4 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BA1B:7BAA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: T008_C7_VI_H4S9_071107 Version: T0084.0 detecting structure #2... 0 done 44 byte(s) read imei: 35931703412769 connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! |
05-14-2009, 00:23 | #6 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | COM4 [VCP0] selected module v2.82 Action: touchscreen calibration mode: 5 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BA1B:7BAA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: T008_C7_VI_H4S9_071107 Version: T0084.0 detecting structure #2... 0 done 44 byte(s) read imei: 35931703412769 connection Ok detecting structure #5 (mode-5)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! |
05-14-2009, 00:42 | #7 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | THIS IS FULL FLASH READING http://www.megaupload.com/?d=PB2Z0WGO |
05-14-2009, 06:51 | #10 (permalink) | ||||||
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | Quote:
Hey all frends i'm tested and 100% work it tyr to change speed you sucsses.......... Last edited by amar181; 05-14-2009 at 06:56. Reason: some text editing | ||||||
calibrate touchscreen failed.what problem is? | genci titi 2002 | Infinity-Box | 16 | 08-15-2009 08:26 |
calibrate touchscreen problemes | DHEERAJ_SHARMA | Infinity-Box | 2 | 06-20-2009 22:50 |
chinese phone calibrate touchscreen problem solve by infinity | robin25 | Infinity-Box | 2 | 03-07-2009 09:34 |
c800+ problem calibrate touchscreen after flashing | goldenploto | SpiderMan | 4 | 01-09-2009 01:42 |
Calibrate Touchscreen on F818.. | LoveLess | Infinity-Box | 5 | 06-13-2008 08:23 |
