Old 05-11-2009, 13:06   #1 (permalink)
azeem781986's Avatar
Member: 503161
Sonork: 100.1584069
Thanks Meter: 470
problem with chinese xtelecom X3128
hello !!!infinity team m having problem with chinese fone x3128 xtelecom
it is sssaying eeprom or ffs area not correct i press yes
mostly sets are powered on with complete formatting but this one is not going to power on
the version of this fone is this:
::E506_B25_PCB01_GPRS_MT6226_S01.00_0.BIN
i make full format but no succes
then i flashed the fone with this firmware on support of infinity box
:::E506_B25_PCB01_GPRS_MT6226_S01.00_0_16m_En_Ru_A r.B0M.bin
but no succes need help regarding this phone
==== log: [5/11/2009 4:47:05 PM] ====
COM3 [VCP0] selected
module v2.82
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:2AC1:06C2
status: FF
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.71F37329.[E506_B25_PCB01_GPRS_MT6226_S01.00_0.BIN_9713BC0D].rpl
identification#1 detection finished
device-id: 71F37329
identification#1 protocol ver: 04
ver. sw 1: E506_B25_PCB01_GPRS_MT6226_S01.00_0.BIN
ver. sw 2: E506_B25.00.0, F243EC68
ffs offset/size: 00800000/001FF000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00800000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00800000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00800000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 506_B25_PCB01_GPRS_MT6226_S01.00_0__system_log_71F 37329_9713BC0D_20090511-165039.B0X.bin
Finished, time used: 194 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Old 05-11-2009, 14:51   #2 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 267
i have 16 mb. bin back up using v-pro.
E506_B3_PCB01_GPRS_MT6226_S01.00_9.B
if infinity support can convert it for i can upload it
Old 05-12-2009, 18:10   #3 (permalink)
Member: 148515
Thanks Meter: 15,716
hello guys!
please upload bin file, i will convert it
Old 05-13-2009, 11:09   #4 (permalink)
Member: 190344
Thanks Meter: 267
sir here it goes
http://www.4shared.com/file/10506592...COM__3128.html
br
hamid
Old 05-13-2009, 19:37   #5 (permalink)
Member: 148515
hello!
please try converted file
http://rapidshare.com/files/23255951...m.B0M.bin.html
Old 05-13-2009, 20:46   #6 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 551
i have also tested bin file of spider man .................i will upload if needed? i have 2 dead sets fixed just today with this file.
Old 05-14-2009, 10:44   #7 (permalink)
Member: 503161
Sonork: 100.1584069
Thanks Meter: 470
thanks sir for converting the bin file
at the moment cstomer's taken back but
he ll come in a day or two i ll try and post result
thanks again
INFINITY=SUPERB BOX
Old 05-14-2009, 19:30   #8 (permalink)
Member: 148515
hello mr zeerik!
i appreciate your offer!!!
but, do not send until we get some test report regarding converted file
Strange problem with Chinese phones jollymolly UCT (Universal China Tool) by ET 6 06-21-2010 08:21
A very big problem with chinese miracle ... asmodi Infinity-Box 10 08-07-2008 17:17
Strange Problem With Chinese Nokia N82 mukasa Infinity-Box 2 07-15-2008 10:23
plz problem with phone Xtelecom flash zakryia Infinity-Box 7 03-28-2008 16:21
Page generated in 0.34936 seconds with 8 queries
