05-03-2008, 00:03 | #1 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 715951 Status: Offline Thanks Meter: 0 | Problem Extracting flash I tried with old chinese miracle and I extracted the flash but always say that it could be corrupted or damaged. Today, I tried the new release of chinese miracle 2.41 and it says that there is no NOR chip instaled? Why now CM doesn't read the phone and the previous versions yes? Here is the log with v2.41: COM3 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Fail Finished, time used: 24 sec Remove/Install battery now ! And this is the log of v2.39: COM3 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... reading structure area... detecting structure... source data: page+spare converting data... done 0x00010000 bytes identification#1 protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN ver. sw2: H800_1_5T15S0416, DE2D56A6 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: D:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.27EADFDB.[RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN_59A9D221].rpl ==================== New firmware detected: RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished reading... checking backup data integrity... source data: page+spare converting data... done 0x04000000 bytes identification#1 protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN ver. sw2: H800_1_5T15S0416, DE2D56A6 ffs offset/size: 02000000/02000000 id-page1 Ok warning: size adjusted by end mark [+00008000], probably incorrect/damaged data nfi area detection finished: Ok file saved: D:\Archivos de programa\InfinityBox\ChineseMiracle\backup_nand_pr obably_damaged_[RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN]_full_20080502-234155.B4M.bin file saved: D:\Archivos de programa\InfinityBox\ChineseMiracle\backup_system_ log_27EADFDB_RATECH28_06A_PCB04_GPRS_MT6228_S02.H8 00_1_5T15S0416.BIN_59A9D221_20080503-010112.B4X.bin Finished, time used: 75265 sec Remove/Install battery now ! What is happening? |
05-04-2008, 21:04 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! it must be quite big. better if you will upload it to www.rapidshare.com and post link thank you |
05-04-2008, 23:37 | #7 (permalink) |
Member: 715951 Status: Offline Thanks Meter: 0 | Hi. I uploaded a few mtk 6228 flash that Chinese Miracle could not extract correctly: http://rapidshare.com/files/11257981..._20080504.html http://rapidshare.com/files/11258246...27.B4M.bi.html http://rapidshare.com/files/11258505...__full_20.html I hope you could make the next release of chinese miracle compatible with these flash and with more 6228.... Thanks |
05-05-2008, 13:01 | #8 (permalink) |
Member: 715951 Status: Offline Thanks Meter: 0 | So... do you know if there is anyway I could extract correctly these full-flashes? I need to translate them and then, put them back into the phones... I really apreciate all your efforts. |
05-09-2008, 18:47 | #12 (permalink) |
Member: 715951 Status: Offline Thanks Meter: 0 | I tried the new CM 2.42 and I it extract the full flash of my mt6228 damaged too. Here is the log: COM3 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... reading structure area... detecting structure... source data: page+spare converting data... done 0x00010000 bytes identification#1 protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN ver. sw2: H800_1_5T15S0416, DE2D56A6 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: D:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.27EADFDB.[RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN_59A9D221].rpl ==================== New firmware detected: RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished reading... checking backup data integrity... source data: page+spare converting data... done 0x04000000 bytes identification#1 protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN ver. sw2: H800_1_5T15S0416, DE2D56A6 ffs offset/size: 02000000/02000000 id-page1 Ok warning: size adjusted by end mark [+00008000], probably incorrect/damaged data nfi area detection finished: Ok file saved: D:\Archivos de programa\InfinityBox\ChineseMiracle\FLASH Original\backup_nand_probably_damaged_[RATECH28_06A_PCB04_GPRS_MT6228_S02.H800_1_5T15S041 6.BIN]_full_20080509-193724.B4M.bin file saved: D:\Archivos de programa\InfinityBox\ChineseMiracle\backup_system_ log_27EADFDB_RATECH28_06A_PCB04_GPRS_MT6228_S02.H8 00_1_5T15S0416.BIN_59A9D221_20080509-193823.B4X.bin Finished, time used: 1911 sec Remove/Install battery now ! Don't know what to do now. I need to translate this firmware |
Support's problem... extracting fail | saiftc2 | Z3X-Team Products | 6 | 04-19-2009 07:01 |
Do we can extract FLASH from phone for flash others with ? | wabou | Smart-Clip | 9 | 03-15-2006 14:39 |
dead nokia 1100 - how do i extracted flash? | cuntsticks | Nokia Hardware & Hardware Repair | 0 | 03-02-2006 21:42 |
problem extracting Ki how long? | bazan | Sim Cloning and Scaning | 0 | 04-26-2005 23:30 |
extract flash/firmware from phone with data cable is posible? | TraXXiTo | Infineon C16X M51 & ARM7 M52 BASED | 0 | 02-12-2003 21:11 |
