02-18-2018, 15:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | Problem with Featured devices based on Spectrum In one word, HANGS!!!! Till Infinity.... Smartphones works good but Featured phones will never complete boot phase. Log Below! Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.02 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR SPRD mode : SC6531 : REV : A000 : NOR Operation : Identify [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! Done! Elapsed: 00:01:35 Reconnect Power/Cable! Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! Error : PMT info not found! Damaged device MCU code! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! Error : PMT info not found! Damaged device MCU code! Send log and report.log to support! Include device info also! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! Error : PMT info not found! Damaged device MCU code! Send log and report.log to support! Include device info also! Reconnect Power/Cable! About this? "Error : PMT info not found! Damaged device MCU code!" It always show up once i disconnect mobile. Mobile is working perdectly. |
