07-08-2006, 22:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Problem To Flash A Cl75 Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... Write Fail Finished Remove/Install battery now ! Time used: 1227 sec IT GOT STUCK ON 4% AND THE PHONE IS DEAD NOW |
07-08-2006, 23:38 | #3 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | PROBLEM SORTED CHANGED CABLE FROM COM TP UNIBOX CABLE RJ45 CHAGE BAUD RATE FROM 11500 TO 230400 Current device: Siemens CL75 Loading file [version 01]... CL75_100D_Main.21M.bin Loaded Err: can't open COM1 COM8 ready COM8 selected Device: Siemens CL75 Checking data, wait... Action: Flash write Write: Firmware Skip: Map/Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22202200 Flash: 98E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write: Firmware area requested/selected: 01/03 Err: wrong answer[]: write request not confirmed Err: write #03: 01080000:00010000 Retrying... Err: wrong answer[15]: write request not confirmed Err: write #03: 01080000:00010000 Retrying... Err: wrong answer[]: write request not confirmed Err: write #03: 01080000:00010000 Retrying... Err: wrong answer[C4]: write request not confirmed Err: write #03: 01080000:00010000 Retrying... Err: wrong answer[]: write request not confirmed Err: write #03: 01080000:00010000 Retrying... Err: wrong answer[]: write request not confirmed Err: write #03: 01080000:00010000 Retrying... Write Fail Finished Remove/Install battery now ! Time used: 169 sec Loading file [version 01]... CL75_100D_Main.21M.bin Loaded COM8 selected Device: Siemens CL75 Checking data, wait... Action: Flash write Write: Firmware Skip: Map/Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22202200 Flash: 98E59F00000000 Boot Done Set baud... 230400 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write: Firmware area requested/selected: 01/03 Write Done Finished Remove/Install battery now ! Time used: 840 sec Loading file [version 01]... CL75_Map_DF-M22.10.21F.bin Loaded Loading file [version 01]... CL75_100_LP01L2707_Catalan_Fr_De_Gr_It_Pt_Br_Es_Tr .21P.bin Loaded COM8 selected Device: Siemens CL75 Checking data, wait... Action: Flash write Skip: Firmware Write: Map/Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22202200 Flash: 98E59F00000000 Boot Done Set baud... 230400 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write: Map/Customization area requested/selected: 01/03 area requested/selected: 02/03 area requested/selected: 02/03 area requested/selected: 02/03 Write Done Finished Remove/Install battery now ! Time used: 308 sec |
Problem to flash new FW to X460 | pele | NSPRO | 2 | 08-27-2005 09:54 |
problem to flash P900 PDA part | shingo000 | Cruiser Suite | 1 | 10-05-2004 18:42 |
problem to flash 7650 | marvik | Trisha & Matrix Flasher | 12 | 12-02-2003 02:56 |
i have problem to flash n500 | BLIDA | VLSI, Conexant, Skyworks and Old Models | 3 | 03-31-2003 13:00 |
Problems to flash/write GDFS to a T68m and a T68i | Burnt Cobba | Sony Ericsson | 4 | 01-23-2003 00:32 |
