02-16-2008, 14:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Problem Formatting FFS Cect E808 i've problem Formatting FFS on one CECT E808, this fone have a JTAG connection on the board which Clearly Shows RX & TX for GND i use -ive terminal of Bettery Connector, when i power on fone and connect with Infinity and read general Information everything seems to be oOK here is the log. COM7 [VCP0] selected Device: Autodetect 6205-6227 NOR Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6205B, E0 Hardware version: D9_S Software version: D9_S_1.2" Software date: 2003.07.29 Barcode: MT012345678901234567 imei: 357869000037330 Finished, time used: 5 sec Power off phone now ! but when i try to FORMAT ffs with COMPLETE method i get the error but it save something on the backup and did format few areas, but fone still power off when sim inside. here is the log of FORMAT FFS COMPLETE. COM7 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! COM7 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! baud autodetection active error: boot initialization step-3 failed: 00 19200 Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #01 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #02 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #03 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #04 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #05 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #06 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #07 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #08 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #09 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #0A in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #0B in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #0C in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #0D in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #0E in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #0F in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb detecting chip #01 in region #00... flash: 0122C400000000:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 001Fx010000] 2Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00200000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DGSUB_PCB01_GSM_MT6205B_DN.D9_S_1_2.BIN ver. sw2: D9_S_1.2, 00000000 ffs offset/size: 001C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished Finished, time used: 36 sec Remove/Install battery now ! COM7 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 1 sec Remove/Install battery now ! Kindly Help me on It. Take Care ENJOY |
02-18-2008, 08:21 | #5 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
Take Care ENJOY | |
02-19-2008, 07:00 | #7 (permalink) |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Now nothing can helpfull because i returned the handset to customer, he was not ready to wait more, and one more thing about your software is that i try to format one another SANDS A203 with the pinouts available with SHELL but in normal mode fone connects without any problem but when i try to connect it to format FFS its not connecting even not detected by the software, so what i did i use same pinout with other box and it works. so try to resolve this problem as well. Take Care ENJOY |
02-19-2008, 20:04 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello imran_qasim! question about Sands A203: which format did not work for you safe or complete? Did you try them both before you used another tool? |
02-20-2008, 08:11 | #9 (permalink) | |
yes i try first all possibilities with Infinity then i try other tool, when phone turned off , it was not connecting with Infinity even if i try to read Detail Information or Formatt FFS Complete/Safe, but with other tool it only takes 3 minutes and fone fixed. Take Care ENJOY | |
05-19-2008, 17:43 | #10 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: bali island Age: 43
Member: 137049 Status: Offline Thanks Meter: 7 | Quote:
complete format was done, but still restrart, safe format not work. phone type "star tech ST67" what can i do sir? now phone always restarting. | |
CECT 199 format ffs success. | rajumobile | Infinity-Box | 3 | 11-09-2008 21:50 |
CECT T689 After format FFS work only with 1 sim | snsoftkiller | Infinity-Box | 12 | 11-04-2007 21:40 |
CECT K808 format FFS ok but callibration screen?????? | .::BHATTI::. | Infinity-Box | 5 | 10-24-2007 16:00 |
Format Ffs Cect V668 How To Do | riyadhkhalid | Infinity-Box | 13 | 09-09-2007 05:53 |
