08-21-2016, 20:51 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Algeria
Member: 756942 Status: Offline Thanks Meter: 81 | Problem with G530H, Need Help Downloaded at last 7 flash files always getting same error [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Any Idea will be appreciated , Thanks in Advance Quote: Wait for phone... Phone found! [ 149 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100534A5330304D001BC62ED63F87 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
08-22-2016, 18:03 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hello, Only matching preloader will help u to solve this issue. Find correct firmware and flash it.. |
The Following User Says Thank You to chandanps18 For This Useful Post: |
