08-13-2010, 20:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 218901 Status: Offline Thanks Meter: 64 | Problem Huawei G7007 Help Support |
The Following User Says Thank You to pr1mux For This Useful Post: |
08-27-2010, 10:11 | #4 (permalink) |
Freak Poster Join Date: Apr 2004 Location: ACCRA
Member: 61877 Status: Offline Thanks Meter: 7 | module v3.55 Device: Huawei-G7007 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B1 62_Ver.B_Apr-27-2010_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bi n nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC27B162 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bi n nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B162.BIN project-id: ENGC27B162, 01D1CE58 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bi n nfi area detection finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Format (HW_STORAGE_NAND)... Disconnect... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B1 62__system_log_20100827-085842.B4X.bin Finished, time used: 6 min 8 sec Remove/Install battery now ! BUT SOFTWARE ERROR:23 on the phone screen . |
The Following User Says Thank You to tomsee For This Useful Post: |
08-31-2010, 10:20 | #8 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Ghana-Accra
Member: 311615 Status: Offline Sonork: 100.1591575 Thanks Meter: 72 | Infinity Team pls help me my Huawei G7007 Software error:23 after unlock...Still the same problem after i have flash it too what is the next step??? |
08-31-2010, 18:33 | #9 (permalink) |
No Life Poster Join Date: Dec 2007 Location: FomTekLAB Mexico-United States
Member: 645603 Status: Offline Thanks Meter: 89 | here the log COM46 [VCP2] selected module v3.54 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC27B162 Version: VER.B 80 byte(s) read imei: 863349xxx connection Ok 185 byte(s) read reading data... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
10-18-2010, 17:25 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we got some similar Huawei model. Work is in progress. if this model will not help us to solve problem with G7007- then we will request for its sample again |
