03-03-2010, 16:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | problem with huewai t161l i think that it is other version of phone, i tried to unlock, read flash and flash but all times same error. -----------------------------------flash log COM13 [VCP0] selected modulo v1.76 Servicio: Huawei-T161L Checkeando datos, espere... Action: write flash Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 8000:8000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... leyendo eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A leyendo eeprom-security... leyendo eeprom-complete... backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Escribir ... reset... error: set erase range error: reset failed Erasing: Firmware error: set erase range error: erase failed: 00400000 Escribir Failed Finalizado, tiempo usado: 1 min 44 sec Quite/coloque la bateria ahora ! --------------log unlock COM13 [VCP0] selected modulo v1.76 Servicio: Huawei-T161L Checkeando datos, espere... Action: "sp-unlock" unlock method-1 Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 921600 Seleccionar velocidad Done Connecting ... Flash 8000:8000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... leyendo eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A leyendo eeprom-security... leyendo eeprom-complete... reading additional data... error: can't read lock-area backup critical area Failed Finalizado, tiempo usado: 1 min 54 sec Quite/coloque la bateria ahora ! it phone is movistar - peru |
Problem with unlocking Samsung E1080 | ..::alexis::.. | HWK | 18 | 09-25-2011 14:23 |
problem with ku990 | nunu.gabriel | Octopus LG/Octoplus LG | 3 | 03-31-2010 12:16 |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
problem with nokia 6234 | pachicoo | Universalbox | 2 | 03-29-2010 15:19 |
