01-24-2008, 12:51 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | man this kind of pinout is the easiest ... try to read volts on pinouts and check - + pins then u will get only 6 left it is so easy |
01-24-2008, 15:56 | #4 (permalink) |
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | good now u ca test like this : connect ground now u have 1 2 3 4 with volts on them and u have two lines RX and TX so u have to check 16 possible connection and if u can not get anything maybe the cpu is not MTK |
N73 problem | usernome | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-30-2010 07:21 |
max key team help n73 ? | sajjadahmad | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-29-2010 16:59 |
need nckia n73 flash file | rangan_kumar | Chinese Models & Cloned Phones | 1 | 04-07-2009 07:40 |
need nckia n73 flash file | somratjisan | Chinese Models & Cloned Phones | 0 | 12-16-2008 11:28 |
need nckia n73 big flash file | ronygsm123 | Chinese Models & Cloned Phones | 1 | 12-03-2008 11:05 |
