problem with kd 86 hang and restart i have one phone is chinese miraceles type kd86 dual sim i have format complet here is logo COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E221A2200:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\kd\eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20080928-110123.B0E.bin flash: 01227E221A2200:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E221A2200:18E59F00000000 Finalization Done Finished, time used: 41 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! my phone only restart i have rehot the cpu but again restart pleease any solution:eek::eek: |
hello! you found second MCU (MCU_b) pinout please repeat search procedure and find first MCU pinout |
yes now my problem solved i find pinout for first mcu and my phone work fine for info pinout is keyboard top 6......rx 10....tx 12....gnd thank you INFINITYHELP HERE IS LOGO COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E221A2200:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\kd\eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20080928-110123.B0E.bin flash: 01227E221A2200:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E221A2200:18E59F00000000 Finalization Done Finished, time used: 41 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! :D:D |
