Old 09-28-2008, 11:43   #1 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
Unhappy problem with kd 86 hang and restart
i have one phone is chinese miraceles type kd86 dual sim
i have format complet here is logo
COM5 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E221A2200:18E59F00000000
flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN
ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000
ffs offset/size: 003C0000/00040000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 003C0000
checking area[00000000]: 00000000-003FFFFF...
eeprom/ffs found near: 003C0000
detecting eeprom/ffs size...
eeprom/ffs size: 00040000
ffs chip: 00
eeprom/ffs area: 00000000:003C0000-003FFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\kd\eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20080928-110123.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 41 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
my phone only restart
i have rehot the cpu but again restart pleease any solution
Old 09-28-2008, 13:16   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you found second MCU (MCU_b) pinout
please repeat search procedure and find first MCU pinout
Old 09-28-2008, 14:08   #3 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
yes now my problem solved i find pinout for first mcu
and my phone work fine
for info pinout is
keyboard top
6......rx
10....tx
12....gnd
thank you INFINITYHELP
HERE IS LOGO
Boot...
19200 fixed
Connecting, wait...
CPU: MT6205
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
ffs chip: 00
Write...
Write Done
Finalization...
formatting...
Finalization Done
Why pc hangs and restart when trying to flash w705 with usb san9090 SETool2 5 12-21-2010 13:52
K550I hange and restart with Sim erazor047 SETool2 0 08-06-2009 12:50
myC-3 hangs and restart with SIM ??? naahou2000 ARM9 BASED M62 / M62+ 0 08-09-2005 17:22
Big problem with 6610 turn Off and restart auto flechazo Nokia Hardware & Hardware Repair 9 02-28-2005 22:10
Page generated in 0.17848 seconds with 10 queries
