02-18-2019, 11:45 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | Problem with MTK/Mediatek v2.05 Same error with forced ext format,Forced FRP,Wipe+Frp Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM24) MODE : PRELOADER PORT PORT : 24 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1904 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D4203CD5AE01D55F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 770AE5102DA24C119019040D36CB4520 DA : USB : HIGH-SPEED Boot done! ERR : 0xC002000C ERR : SEC_WRITE_DATA_NOT_ALLOWED ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! |
The Following User Says Thank You to zapata13 For This Useful Post: |
02-18-2019, 11:52 | #3 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Hi, try with memory tool, Select and wipe FRP partition reboot wipe data and cache from recovery. Result? |
The Following User Says Thank You to yuranc8 For This Useful Post: |
02-18-2019, 19:13 | #4 (permalink) | |
Member: 1958094 Status: Offline Thanks Meter: 57 | Quote:
Not solved Operation : Memory Tool Init [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM24) MODE : PRELOADER PORT PORT : 24 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1904 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D4203CD5AE01D55F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 770AE5102DA24C119019040D36CB4520 DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Erase Memory Erase selected partitions [1] [0] Erase partition : FRP ERR : 0xC002000C ERR : SEC_WRITE_DATA_NOT_ALLOWED ERR : 0x00000000|0x00000000 Shutdown MemoryTool due fatal error Error : Failed to write data! Connection ( or secured region??? ) problem! Check cable, battery, connection and drivers! Reconnect Power/Cable! Close MemoryTool session Done! Elapsed: 00:01:15 | |
02-18-2019, 19:25 | #5 (permalink) |
Member: 1958094 Status: Offline Thanks Meter: 57 | test brom mode,preloader only Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM26) MODE : BOOTROM PORT : 26 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1904 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v4 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D4203CD5AE01D55F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 770AE5102DA24C119019040D36CB4520 DA : USB : HIGH-SPEED Boot done! ERR : 0xC002000C ERR : SEC_WRITE_DATA_NOT_ALLOWED ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! |
02-19-2019, 03:21 | #7 (permalink) |
Member: 1958094 Status: Offline Thanks Meter: 57 | Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM286) MODE : BOOTROM PORT : 286 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v4 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D4203CD5AE01D55F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 770AE5102DA24C119019040D36CB4520 DA : USB : HIGH-SPEED Boot done! ERR : 0xC002000C ERR : SEC_WRITE_DATA_NOT_ALLOWED ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! |
02-19-2019, 04:34 | #9 (permalink) |
Member: 1958094 Status: Offline Thanks Meter: 57 | 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM135) MODE : BOOTROM PORT : 135 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v4 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464536324D4203CD5AE01D55F1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 770AE5102DA24C119019040D36CB4520 DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Erase Memory Erase selected partitions [1] [0] Erase partition : FRP ERR : 0xC002000C ERR : SEC_WRITE_DATA_NOT_ALLOWED ERR : 0x00000000|0x00000000 Shutdown MemoryTool due fatal error Error : Failed to write data! Connection ( or secured region??? ) problem! Check cable, battery, connection and drivers! Ready! Operation : Erase Memory Erase selected partitions [1] [0] Erase partition : FRP ERR : 0xC002000C ERR : SEC_WRITE_DATA_NOT_ALLOWED ERR : 0x00000000|0x00000000 Shutdown MemoryTool due fatal error Error : Failed to write data! Connection ( or secured region??? ) problem! Check cable, battery, connection and drivers! Reconnect Power/Cable! |
02-19-2019, 05:38 | #10 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | you selected DA_PL in Base DA_PL have protected some partition to format Leave everything as default just select MTK_AllInOne_DA and repeat it will be ok |
02-19-2019, 10:04 | #14 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | In bootrom mode chose MTK_AllInOne_DA and EMI 4 and ADR MODE EXTANDED and open memory tool and do operations ? Last edited by rebainoor; 02-19-2019 at 10:11. |
