Old 11-18-2008, 17:13   #1 (permalink)
EMOTION BBSR's Avatar
Member: 194285
Thanks Meter: 53
problem with my pinfinder
searching adapter at COM3...
adapter found, version: 2000
S/N: xx
done
Initializing...
done
after pressing power
S/N: xx
done
Initializing...
done
Cable: 1x8 (L8A)
too many retries
too many retries
Power On !
after pressing find it
software version: 1.15
cable type: 1x8 (L8A)
platform: MT: MT6205, MT6217-MT6228, MT6230
too many retries
can't find adapter
too many retries
too many retries
Power On !
Set parameter to value 20 (or more) and repeat operation "Finder activation tries"
tryed with two phone
infinity team please guide.
Last edited by InfinitySupport; 11-19-2008 at 01:09. Reason: S/N deleted. PLEASE !!! Never show S/N in public forum !!!
Old 11-18-2008, 19:49   #2 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
some phones just dont keep tx/rx in system connector.
some phones use different than mt62xx MCU.
if you are new pinfinder user i would advice to start from phone with known pinout.
so you will be sure that MCU type is set correctly, pinout is present in system connector.
also pay attention to "Finder activation tries " set it to value 10 or more.
remmember that phone must be powered from box power.
absolutely necceserry before searching pinout make sure that phone is able to power On from box power.
for doing this press button "power" red led should indicate that power lines is powered now.
try to power On phone. If it is powering On- you can continue with pinout search.
please ask more if you still have questions
Old 11-18-2008, 22:56   #3 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
pls follow the instruction that infinityhelp said
check first with a good set , after detecting the pinfinder adaptar with infinity box press ''power on'' button on pinfinder soft and then press the handset power button and see is the phone can on or not
after that select the correct cable/port name from cable list
then select the cpu type if u know , otherwise select the last option on that list
then press ''find '' on sw and keep press the handset pw button
and remember everytime u try to detect the pinout u should again off/on the power form box(by pressing the power on/off tab from sw)
if u still have same problem pls post with log or details sure u will get help from infinity team
Old 11-18-2008, 23:45   #4 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,022
@e_motion_bbsr
@sharmin
problem PinFinder Adapter to Unibox RJ45-RJ45 mirrored cable
http://www.infinity-box.biz/download..._PinFinder.pdf
Old 11-19-2008, 16:52   #5 (permalink)
Member: 194285
Thanks Meter: 53
yes i have fault in my cable which connects infinity to pinfinder
thanks to all
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 11:07
I have a problem with Infinity pinfinder on pinout magucha Infinity-Box 1 12-27-2009 21:02
Help please with my PinFinder ????? geovanny78 Infinity-Box 6 09-11-2009 23:04
HELP with my HUG Q-23 can't find with my pinfinder! jaye_patok Infinity-Box 8 02-01-2009 17:51
Strange problem with infinity + pinfinder sairat Infinity-Box 10 01-10-2009 18:29
Page generated in 0.27847 seconds with 9 queries
