Old 03-28-2008, 09:17   #1 (permalink)
TEHGSM's Avatar
Member: 109729
Thanks Meter: 36
Problem with N95 2 sim slider
Hi i have 11 pcs N95 2 sim slider with same prob. restart with second sim.
original firmware is NLJ26_06A_PCB01_GPRS_MT6226_S01.MT6226_S01_MAUI_06 B_W07_04_MP_V3.BIN
I tryed format safe and complete, and write imei. Not work, same problem.
I flashed with CM_Nokia-N95-2sim_NLJ26_06A_PCB01_GPRS_MT6226_S01.N95_4B0_BYD77 87_OV_BT_RUSSIAN_FRENCH_ARABIC_ENGLISH_2_5_16m_En_ Ru_Fr_Ar.B0M
format, write imei.
At first phone see both sims but can call from second sim, but display not calibrate. After calibrate imei and factory reset phone don't see again second sim..
Wich firmware or what can i do pls...
Anny help is appreciated
Old 03-28-2008, 11:48   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must use match to your original version flash file.
there is a lot of different flash files with many languages on support
just make search at bottom of page:
http://forum.gsmhosting.com/vbb/showthread.php?t=499453
Old 03-28-2008, 15:08   #3 (permalink)
TEHGSM's Avatar
Member: 109729
Thanks Meter: 36
I do that and is not on suport area.... same like this flash : E553AGENT_F1_E553_GSM_MT6205B_DN.01_5.BIN
i need this too, i have 3 pcs of n N5 dual sim (not slide)
wbr
Old 03-28-2008, 20:23   #4 (permalink)
Member: 148515
hello!
here is flash files which you requested in first posting:
flashfiles/ChineseMiracle/_MT6226/CM_Nokia-6500-2sim_1x12pin_NLJ26_06A_PCB01_GPRS_MT6226_S01.MT622 6_S01_MAUI_06B_W07_04_MP_V3_16m_En_Ru_Fr_Th_Vn_Ar. B0M.bin
flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N73-CPU1_2x6pin_NLJ26_06A_PCB01_GPRS_MT6226_S01.MT6226 _S01_MAUI_06B_W07_04_MP_V3_16m_En_Ru_Fr_Th_Vn_Ar.B 0M.bin
here is flash files for second post:
flashfiles/ChineseMiracle/Anycool/Anycool-D66+_CPU2_E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_ 1__E553AGENT_F1_E553_GSM_MT6205B_DN.01_5_4m_En.B0M .bin
flashfiles/ChineseMiracle/_MT6205/CM_Cect-T689-CPU2_E553AGENT_F1_E553_GSM_MT6205B_DN.01_5_4m_En_w _eep.B0M.bin
please note that second flash file which you requested is CPU2!
flashing it will not help if phone restarts
I Face Common Problem In N95 2 Sim Slider chiragsp_codes Infinity-Box 4 11-23-2007 10:43
Page generated in 0.12828 seconds with 9 queries
